1⁄700Building the Admiral Nahkimov, 1889
13
Next, 3.4 in main deck guns had the races constructed of flattened wire, and the guns were made of thick brass wire barrels, PE and styrene for the carriages.
photo 1
At this stage, the 2 x mast base plates were fitted, which were made of painted paper, and the belaying pin rails made of old stainless steel handrail, and turning block sheave posts using styrene strip.
photo 2
The holes for the masts were drilled all the way through the hull...the masts would be required to carry significant rigging loads later; even in stretched sprue there is considerable tension build-up.
The lower masts were then furnished with paper platforms infused with CA glue, and had ratlines rigged on using the excellent PE brass ratlines from Atlantic Models, available from WEM.
photo(s) 3 & 4
Small searchlights on the bridge wings were scratch built on tapered ends of CA infused toothpicks...they were so tiny that nothing I had came even close in my scrap-box.
The davits supplied in the kit did not resemble any on the ship, so I made all new davits using fine fuse wire, with the exception of the large swinging types for the large steamboats; these were cut down and thinned in all dimensions from the existing resin supplied items, had styrene fine ends grafted on and finally fitted with brass aircraft wheels as pulleys. The forward beam type davits were made of brass handrail, with stretched sprue for the curved supports.
photo(s) 5 & 6
Not a single boat from the kit was used; the boats came from a variety of scrap-box sources, WSW, Kombrig, WEM, and even some Modelkrak. The small steam launches were hollowed out and a small boiler, engine and funnel fitted with styrene rod. Some of the boats were the right beam and outline; They were shortened by cutting off the stern and adding a fresh transom made of paper.
photo 7
Small metal anchor chain was then fitted coming out of the drilled hawse pipes, and the anchors were a combination of PE flukes, and styrene made stock, in which unusually, these anchors had a recess in the hull sides, for the inboard flukes. The hawse-pipe covers were filed to shape from scrap brass PE fret surround.
photo 8
photo 1
photo 2
photo(s) 3 & 4
photo(s) 5 & 6
photo 7
photo 8
OMG...I'm not worthy (que bowing smiley).
Thank you Jim for sharing your build process if even a tiny bit has rubbed off on to me I will be over the moon
Ciao
Luciano
JUN 28, 2007 - 06:14 AM
There are some ship names that makes my ears go up like a golden retriever in front of a rabbit, Admiral Nakhimov belongs to those ones!
not only IMHO Jim is the best around at what he does, he is also quite special for me as he likes the same boats as I do!
fantastic build, great and generous SBS to read, as usual Jim's stuff kinda put new frontiers to what's humanely possible to do in terms of miniature and ship building.
now I can rub my head frantically on the wall and say "outstanding, outstanding, outstanding" for the whole evening
JB
JUN 28, 2007 - 07:11 AM
Jim,
I don't know how you do ships that small, it was hard for me to see and I was looking at the photo....LOL!
Great Job!!
JUN 28, 2007 - 08:16 AM
It's great to have (finnaly) Jim's work published here!
As usual the workmanship, craftmanship and the trainned spiders make an excellent result!
Jim I owe you another at Telford
JUN 28, 2007 - 09:44 AM
Top build by the top dog himself, very special,
Cheers, Jim
JUN 28, 2007 - 08:09 PM
Quite simply, an example of the best modelling in small scale you will see. We can all only look at Jim's work and take what we can from it to improve our own skills. Great to see you on here.
Mike
JUN 28, 2007 - 09:11 PM
Well said, Mr. McCabe, and yes, I do agree whole heartedly on all above points, mate..
And just to keep the coals stoked, I have another Baumann feature in the works as we speak..
Keep watch,
JUN 28, 2007 - 10:39 PM
hello gentlemen!
thanks for the warm welcome! Nice to meet some old as well as new friends!
Jim Baumann
JUN 29, 2007 - 07:12 AM
Welcome aboard JIm. Nixt to see your excellent Nakhimov again.
Rob
JUL 01, 2007 - 09:30 PM
Copyright ©2021 by Jim Baumann. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-06-26 00:00:00. Unique Reads: 6755
