Dave's Tugboat Project #2
7
I thought that a taller smoke stack would make the tug look a older than the first,
A piece of PVC pipe seemed to be the perfect size for a replacement. I cut it to the length I wanted and ran my tubing cutter around the middle to score a line to glue a strip of plastic to add some detail to the stack. I fitted the tube to the base.
For the detail on top of the stack I glued it to a piece of styrene, then cut the hole out and filed the outside edge to shape. I wrapped a band of plastic under that and a thinner band around the middle along the line I scribed with the tubing cutter. Just a little more height on the stack made notable difference.
As much as I liked seeing all three in natural light, I enjoy seeing the pieces in detail while in construction.
I really appreciate all the scratching you do – construction over assembly. It really puts art into it when you make custom pieces to meet your own ends.
Looking forward to number three and your future projects.
SEP 22, 2007 - 02:18 AM
Easy to read and a marvell to watch!
Excellent SBS and a very unusual project!
Congratulations Dave
Excellent editing Mark
SEP 22, 2007 - 03:41 AM
Hi Dave,
Excellent bit of work, the tug looks first class.
Thanks for sharing.
SEP 22, 2007 - 06:44 AM
A delightfull build and a lot of fun just watching the transformation.
This takes modeling to a new dimension when you realise it began as a little plastic model. I was inspired and have bought the Revell tug Lucky XII to see what I can do. Will let you know how I go.
Good work!
Les
SEP 22, 2007 - 03:35 PM
Thanks everyone. Its great to be able to share my models with people all over the world.
OCT 01, 2007 - 12:38 PM
Copyright ©2021 by Dave Roehrle. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-09-22 00:00:00. Unique Reads: 5906
