Dave's Tugboat Project #2
7
To replace the hatches for the rope lockers I punched holes in sheet plastic with a hollow punch. Then rough cut them to shape. I punched the hatches out of sheet aluminum. I aligned the holes in the plastic and glued them together with Elmer’s Glue. With them glued together I filed all 4 to the same size and then pulled them apart. For the handles on the hatch covers I drilled holes and looped wire through them. And, glued them with super glue. To simulate a hinge I formed wire and glued it to the other side. The hatches will be attached to the base when they are in position on the deck.
As much as I liked seeing all three in natural light, I enjoy seeing the pieces in detail while in construction.
I really appreciate all the scratching you do – construction over assembly. It really puts art into it when you make custom pieces to meet your own ends.
Looking forward to number three and your future projects.
SEP 22, 2007 - 02:18 AM
Easy to read and a marvell to watch!
Excellent SBS and a very unusual project!
Congratulations Dave
Excellent editing Mark
SEP 22, 2007 - 03:41 AM
Hi Dave,
Excellent bit of work, the tug looks first class.
Thanks for sharing.
SEP 22, 2007 - 06:44 AM
A delightfull build and a lot of fun just watching the transformation.
This takes modeling to a new dimension when you realise it began as a little plastic model. I was inspired and have bought the Revell tug Lucky XII to see what I can do. Will let you know how I go.
Good work!
Les
SEP 22, 2007 - 03:35 PM
Thanks everyone. Its great to be able to share my models with people all over the world.
OCT 01, 2007 - 12:38 PM
Copyright ©2021 by Dave Roehrle. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-09-22 00:00:00. Unique Reads: 5906
