1⁄350USS Missouri
11
MSW Crewmember Louis Carabott [loucar] takes us along for a cruise with the Mighty Mo as she goes In Harms Way looking for the enemy.
Scale 1/350….Make Tamiya
The model was built a while ago and straight from the box with some detailing added to it. A corresponding photoetch set was used to further detail the ship.
The Project...
Model USS MissouriScale 1/350….Make Tamiya
The model was airbrushed with a mixture of enamels and acrylics for bright and dark shadowing. Oils were also used to weather this mighty ship.
Maybe its the lighting or the way the camera interpretted the color, but i think the decks and upper surface should be a bluish color rather than grey. I don't have the specific color but i think most of the warships during mid to late WW2 used a bluish stain on the decks
JAN 20, 2010 - 06:54 AM
You are very right steve....Actually the decks are painted with in gray bluish tint...I am not a good photographer...so there's the result...grey:):)....I try different lighting and I end up with different colours of the same model:):)
Take care and best regards
Louis
Malta
JAN 20, 2010 - 09:44 AM
Hey Louis!
As a fellow 1:350 fan, I am especially impressed with your water effects--it can be tough (for me anyway) to make the sea look so realistic in the larger scales.
--Karl
P. S. That's a mighty impressive flight line in the background as well; if the aircraft were real, you'd be a power in the central Mediterranean!
JAN 21, 2010 - 05:53 AM
Very nice work on the Big Mo. I'm also impressed with the aircraft display in the background.
JAN 21, 2010 - 06:20 AM
Hi all
Thanks for your kind comments about my model. Yes Used to do 1/72 scale aircraft a while ago ..I have a collection of about 200 of them. I do figurines as well. I also used to build 1/72 scale aircraft dioramas always with wartime Malta as a theme I've got about 6 of them at the Malta aviation museum...they r too large to keep at home.
I started modelling ships about 5 years ago and that was it...I got hooked....they are my passion...
Karl I sculpt the seascape using just common toilet paper:):) and diluted pva glue and finish it off with a layer of creamy pollyfilla....then it's just household pain....t
Will soon finish the Yamato and hope to post som e pics of the build....
Best regards
Louis
Thanks again
Louis
JAN 21, 2010 - 10:32 PM
That's a remarkable result with toilet paper!
For the carrier campaign I will be turning to a Malta Spitfire delivery scene...I just need several dozen 1:350 Spitfires!
--Karl
JAN 22, 2010 - 10:18 AM
Karl You can have a look at my model of the Illustrious in 1/400 scale in this site.....It has spits on....I scratchbuilt one and made a mould and a friend of mine casted quite a few in white metal....they will do for a 1/350 scale project..I am quite certain of that.....You gave to scrtacbuilt the undercarriage...If you want I can mail you one and you can do the rest....they need a bit of cleaning , but they will do....
just say the word friend
best regards
Louis
JAN 23, 2010 - 01:52 AM
Hi Louis!
That's a generous offer--I located a retailer in Britain who advertised resin Spits in 1:350 but he hasn't replied to my inquiry in a month.
I've been meaning to try out RTV molding and the Malta project is the perfect project, so let me take a wack at it first and then we'll see about the 1:400 mold.
--Karl
JAN 23, 2010 - 06:58 AM
Hi Karl no problem I will mail you a couple u have to give me your address though....you can email me on [email protected] and like so we can keep your address private....
always glad to help a fellow modeller
best regards
Louis
JAN 23, 2010 - 10:44 AM
Copyright ©2021 by Louis Carabott. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2010-01-19 00:00:00. Unique Reads: 8576
