1⁄35Building the Revell 1:72 VIIC u-boat
13
This article is about the Revell 1:72 VIIC u-boat (no. 05015). A famous kit already, and probably one of the largest submarine models around for a decent price (at least as far as I know) I was surprised to see there wasn't an article about it yet, so I decided to write my own, to give those who are interested in this kit an idea of what it's like to build it....and to encourage others to built this kit as well! As usual for me, I built this kit OOB. I also didn’t use references etc, I just relied on the Revell instructions and I also used some examples on the internet for painting. So, what I’m trying to say here: don’t use this article as help for an 100% accurate built…..
Part 1: before building....
It's Tuesday, around 17:10. I was eating a pizza and watching TV. The day before, I ordered a Revell 1:72 VIIC u-boat, and I was hoping it would arrive today....but packages never arrive after 16:00, so I gave up and accepted I had to wait another day for it. But then suddenly the door bell rings. I opened the door and saw the delivery man with a HUGE box on his shoulder. "Is this for you sir?". Yeah!
Part 2: choices....
When I opened the box I saw 2 huge hull parts, 8 sprues, and instruction book, a decal sheet, a paper sheet with flags, wire, and the instructions. I took a quick look at the clock and saw I had to go to work in 5 minutes. I used the time I had got left to take a look in the instructions. I saw I could choose from 6 u-boat versions. Two are early war u-boats with the big saws (net-cutters) on the front of the u-boat and the other four are later-war u-boats without the saws. Other differences can be found in painting/camouflage schemes. I decided to build an early u-boat, the U-552.Part 3: finally....
Wednesday, around 19:00 Finally I could start building. I was late home from my girlfriend after work the evening before (which isn't a bad thing Jessica! - Martin) and this day I was at school, but now I could really start building! I was excited already, and that's not very surprising. The model is much bigger than my usual 1:35 armour, and it just looks very cool. The first step is the assembly of the torpedo tubes. You can leave all 4 tubes here open or closed. Unfortunately the two lower torpedo tube doors are a little too big, and so they don't fit. I wanted to leave two doors open anyway, so to make it myself easy, I decided to leave the lower torpedo tubes opened and the top torpedo tubes closed. After the assembly of the torpedo tubes, the assembly of the two big hull parts followed. Not too hard to do. After cleaning the hull parts from flash etc, I glued the two parts together, and used masking tape to keep it nicely together. I went to bed and let the glue dry for a night...Comments
Hi
Great job. Your weathering is very well done.
Now my Flower cl corvette is sniffing its nose :-)
Tom
JUN 21, 2005 - 04:23 AM
Now I really need to see this one in real Awesome job on the feature Martin. Congrats!
JUN 21, 2005 - 04:53 AM
A very entertaining read, and a lovely build of the U-boat. The pre-shading came out very well I think. Thanks Martin!
JUN 21, 2005 - 07:32 AM
Martinnn
I've got nothing more to add to the comments of the other guys. Very entertaining read, a lot of info, and very professional pics.
I hope you made a good deal with mr. REvell on this one, cause he'll sure be selling a lot more of these babies now your article is posted.
But, as a marketing graduate, just a small hint:
Everything sells better if you put a nice model holding or slightly touching the object you're trying to sell.
So, in this case, how about a nice model holding your model?
I know you've got both at your disposal....
just kidding...
great work!
JUN 21, 2005 - 08:12 AM
Martin,
Great job on the build and thanks for taking the time to write an in progress article.
regards,
Robert
JUN 25, 2005 - 10:03 AM
Martin ...... Well done! An interesting read. You did a fine job with the VII C. I'm glad you wrote the article. I will try the pre shading when I build mine. I can't wait to see what you come up with for DDD2.
JUN 25, 2005 - 04:30 PM
Hi Martin,
As someone who is taking a break from 1:32 aircraft, and who has received this kit as a gift, I look forward to using your excellent model to help me build mine! First shipwrighting job ever!
Best Regards,
David.
AUG 25, 2009 - 07:52 AM
Copyright ©2021 by Martin Noorloos. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2005-06-21 00:00:00. Unique Reads: 92839
