The cat's is out of the bag!
If you can read this, thank Santa Claus!
Navy Yard Number 4-
Scratch Built IJN Carrier JUNYO
4. Creating the Hull
The main materials used for the full scratch building were plastic sheets and rods from Evergreen. The quality is unusually soft so it is easy to handle that is why it is my favorite. However since it is soft it is also easy to distort. Because of this the hull bottom part from the Tamiya kit was used for the creation of the hull, it was a countermeasure to prevent distortion. However since the length of the hull varied from the materials I have, it was extended approximately 6 mm. Also I conducted re-examination of the hull line at the same time. If I conduct this operation by using the kit, the issues I had to face “How can I extend each section? Also, how could it match consistently overall?”. Since the scratch built hull was created after the sides of the hull (which is usual) it is not necessary to worry about any problems. This type can be said to be a good point. Reference materials are also published but, since it is okay to use the Tamiya kit hull as the solid drawing, the creation of the hangar partitions was made by referring to the kit.
5. Creating the Sponsons and others on both sides
This section with the etched machine guns that were installed later on, it became the point of which how could it be finished up without any sense of discomfort? The creation was conducted by 0.25 mm thick plastic sheets. It was a case of using the kit but you should take note of the thickness of the machine gun sponsons. The part being close to 1 mm thick is the original cause the gap between the flight deck and sponsons would become narrow, giving a sense of horrible balance. As a solution for this section, the sponsons were created by 0.25 mm plastic sheets, the thickness of the sponsons themselves that was attached to the lower surface of the gutter attached to the hull going from 1 mm to 0.25 mm lowered the position for attaching the machine guns by 0.75 mm. By accumulating the “petty device”, a difference was given when finishing up after completion. In the case of 1/700 models there is a point of inquiring the juggling around of it’s little control but how many millimeters, comma what difference in millimeters on the actual warship would differ in the completion. Even though being easy for 1/700 models it can be frightening. Next I will write about the position and distribution of the machine guns. JUNYO at the time of the sea battle off Marianas had carried on board sixteen triple mounted machine guns. The distribution and position were two on the starboard side from the bow (the place where the rocket launchers are at on the kit). Four of them from the stern. Two from the bow on the port side. Four in the middle. Two on the stern. One each in front and behind the bridge for a total of 16 guns. I hear during the production that utterance “What about the rocket launchers at the time of the Mariana battle?” but in photographs during the listing test of May 3, 1944, there are no rocket launchers photographed. Because of that to satisfy the common view it was finished up with that item.
6. Creation of the bridge
Even the creation of the bridge was done all by plastic sheets. It consisted of five stories. On the first story were the direction finding room, bridge wiring room, repair crew waiting room, signal flag stowage room and others. On the second story becoming the lower bridge deck, it had the radio telephone room, skipper and executive officer bedroom, direction finding room. On the third story which became the upper bridge deck, It had the chart room, rudder room, direction finding room. The fourth story which became the compass bridge deck had the compass bridge and messenger station, take-off and landing command post and outlook stations. The fifth story had the anti aircraft command post and outlook station. After investigating the layout of the interior, I went into the production of the bridge. The bridge was created by stacking up in a box-like fashion one story at a time. Since the funnel was an erect style, it tilted outward at a 26 degree angle. This was the solution in order to drastically reduce the influence of the exhaust received at the time of deck landings. The peculiar funnel was created from a rough shape glued onto a plastic square rod, it was created by refining with a rooter (electric drill?). It is a digression but, with the funnel being damaged by receiving a direct hit at the sea battle in the waters off Mariana, there was likely a slight difference after the repairs. The funnel before the Mariana battle compared to the funnel after the battle was slightly wider, the image likely has a sense of being ‘rough’. Since there are no references for the dimensions, the funnel was created to be slightly wider than the Tamiya kit parts. Also it is necessary to take cautions since there are changes observed in the exhaust pipes surrounding the funnel. The interior of JUNYO had much of the surface area occupied by the chimney connected to the funnel, the places were the functioning of the bridge was accomplished is well understood by being smaller than what the eyes can see. The bridge having the erect funnel started with JUNYO and also was on TAIYO and SHINANO. Next is the radar equipments on JUNYO, equipped with two 2-1 go radar and one detector. One of the 2-1 go radar was attached to the fifth story of the bridge, the detector was installed on the upper part of the aerial wire extension pole behind that. The other 2-1 go radar was installed on top of the fight deck on the port side towards the stern. These 2-1 go radars had limits on their height since they were the telescopic style, as for the one installed on top of the bridge the shape is apparent. Also in regards to the 3-1 go radar at the time of the sea battle off Marianas it was no installed on JUNYO. The installment was after this battle.
7. Creating the Flight Deck
The creation of the flight deck as well was done from Evergreen’s plastic boards. The wooden deck section was created by using grooved plastic boards. The edges surrounding the flight deck had steel plate slip-guards. I considered using etch parts as well but considering the balance with the entire product, the use was ended since it could be seen floating above only at this area. The attachment of the edges was created by using 0.25 mm flat plastic boards. This resulted in a step on the areas of the edges with the flight deck but, the role was to stiffen the entire product after that stage. At the painting stage to clearly have different colors with the flight deck, the finish could be seen better. On the concrete section around the flight deck and the two elevators, 0.13 mm thick plastic boards were used. By using plastic boards that had different thickness with the surrounding areas, the goal was to make the adjacent parts look better. Even though using 0.13 and 0.25 mm boards after conducting several sanding down until it was finished, actually those thicknesses became a non- issue. It was necessary to thin down some of the line molding of the kit specific for the Mariana battle. The weather vane marking at the center of the vessel was lacking since there are no photographs. Please refer to it. In order to finish up the flight deck nicely, there are stickers that represent the wooden deck currently. I thought that this was a better answer by using this.
8. Etched parts used
Currently there are many etched parts developed and sold by each company. With the parts being plentiful it doubles the satisfaction for the creation. However on the other side, there actually few specific parts. Currently there are many supplies of the same products that use similar parts. I thought strongly “Is this possibly good?”. Well I will list the etched parts used on JUNYO.
Fine Molds: triple mounted gun shield, searchlight cover, 2-1 go radar, detector, boat davits, collapsable masts, windscreen.
Gold Medal (handled by Pit Road): PE01 USN general accessory set, hand rails, window frames, ladders
Joe’s World: Carrier landing markings, fairlead
These etched parts were utilized. On top of creating the model “by all means one must use etched parts” is really not the case. It is because one can see that scratch build parts is okay. The etched parts, completing the product I wanted to create myself, I thought of as “simple parts”. The etched parts for me is not the main role. Even based on reports of new etched parts, currently I was obsessed with “how can I complete without showing the cemented surfaces of the parts?”. If improving the techniques I can believe in the power to create “individualism and expressive strength”. If only by gluing on the parts, whom as modelers would likely copy the products which is why I would not want to create them. The style is an individual asset.
9. Creating the high angle guns
The high angles guns were self-created by plastic boards. As always it was created by processing the plastic scratch parts used on Tamiya’s SHINANO but, with no surplus of money they were self-manufactured. The Clipper Models metal barrels were used for the gun barrels .
10. In regards to other sections
(1) It is about the areas that protrude out at the lower part of the high angle gun directing equipment that was on the front side of the bridge but it is said that was not present at the time of the Mariana battle. However the photos of JUNYO during the listing test on May 3, 1944 can verify it’s existence. Thus this item was created.
(2) The creation of the mast, the one behind the bridge and above the bridge was created by etched wire pats and 0.2 mm brass wires. The four collapsable mast were made by Fine Molds. Among the four masts the one on the rear starboard side had a V-shaped tip so it is necessary to take note.
(3) The triple mounted machine guns all had shields, in regards to the fire directing equipment, none were molded on. All of these can be verified by photographs.
(4) Camouflage
JUNYO at the time of the Mariana battle was not camouflaged. The hull was in warship color, the deck in tan. There were lines on top of the flight deck but the original color white completely floated up such that it was finished up in light gray-white. Like that aforementioned, there was not a weather vane indicator in the center. Also on the center of the same vessel there existed a line indicating the line up position of aircraft that can be verified by photos taken at the time of the Mariana battle. The color is understood to be in red and white and placed on top of the deck. JUNYO that was created was done by products that shows an overall balance. Thus the attachment of small objects like the binoculars was extremely restrained. “Obsessed with the way I created it myself, I created an original product” which made me quite happy. Since I thought carefully about this situation, it is likely I will not read nor see the creation report and products of other modelers. Due to this example I always thought about wanting to create items.
