MSW-BUILD CONTEST-1/700 HMS ILLUSTRIOUS
Posted: Sunday, August 31, 2008 - 11:44 PM UTC
"Build Session 3 closed~Keep Modeling!"
beefy66
KitMaker: 971 posts
Model Shipwrights: 645 posts
Posted: Monday, September 22, 2008 - 01:40 AM UTC
A small update so far this month,Have now finnished the main correction of the poor fitting bow area.So after all the filling and sanding I washed the hull to get it as clean as possible and began to prime the lower hull to check for any more smaller imperfections.
I,ve found a couple of small gaps in a couple of areas and will correct this week,will also carry on with the build up of the superstrcture. Gent,s a question of choice do most of you fit and glue your sub assembleys before painting or do you think it is best left off to paint the flight deck.
Posted: Monday, September 22, 2008 - 01:59 AM UTC
Hi Keith
Time to wash up your ship
As to your question, I would like to suggest painting subassemblies (hull + superstructures) and work them separately... when ready, glue them together and give the final touches.
Hope this helps,
Hope this helps,
Tailor
KitMaker: 1,168 posts
Model Shipwrights: 676 posts
Posted: Monday, September 22, 2008 - 05:39 AM UTC
Follwoing a good general rule "Handle painted parts a little as possible!", I'd glue first. Then close the gaps with white glue. Then paint the decks and mask them off. Then paint the verticals.
I did try subassembly paiting first, but you'll never know how big or small the gaps in the fusion line between deck and vertical structure will be. Sometimes they are pretty big (See my Sovremenny)
...but that just how I do it.
Guido
Guido
beefy66
KitMaker: 971 posts
Posted: Wednesday, September 24, 2008 - 01:34 AM UTC
So it,s either OR kind of thing depending on modellers choice. I think for this model I,ll go with the Skipper on this, have now almost done the main superstrucher apart from the smaller details. This is the dry fit to the hull and primed, have found a couple of scratches on the deck from removing the raised deck lines but will correct and now move on to getting the aircraft ready.
.beefy66
KitMaker: 971 posts
Posted: Wednesday, September 24, 2008 - 01:57 AM UTC
beefy66
KitMaker: 971 posts
Posted: Thursday, September 25, 2008 - 01:53 AM UTC
Sorry about the poor pics but think I have it now.Any way have found gaps in the build of the superstucture and will correct ASAP also a pic of the jump ramp after all the filling and sanding work. Still some to do but nearly ready for the first coat of paint
the gaps are at rear and base of the front funnel and also on the join line at the very rear of the superstructure.
and still a small join line showing on the side of the ramp.
Posted: Tuesday, September 30, 2008 - 09:46 PM UTC
"Build Session 4 closed-Keep Modeling!"
beefy66
KitMaker: 971 posts
Posted: Wednesday, October 29, 2008 - 08:10 AM UTC
Mark having trouble getting pictures into my BLOG gallery do I have to delet some of the images like it says or am i supposed to keep them all in there. Because i can,t seam to get my camera to get the images any smaller, might get lucky at Xmas with a new one from the wife
if I,am lucky
if I,am lucky
beefy66
KitMaker: 971 posts
Posted: Friday, October 31, 2008 - 04:40 AM UTC
SO this month after getting help with my images through Gunny and freinds Ive painted the base gloss black and added dark gray to the flight deck
and the black stipe for the flight path which will now be masked off and a mottled dark and light gray added.Have also masked the lower hull and painted flat black
and with the masking pape off
painting in sub assemblys also made a start on the airarm of the ship harriers and seakings
beefy66
KitMaker: 971 posts
Posted: Friday, October 31, 2008 - 04:44 AM UTC
Seams as though there are more prblems
[img[http://gallery.kitmaker.net/data/22114/Picture_1173.jpg/img]
beefy66
KitMaker: 971 posts
Posted: Friday, October 31, 2008 - 04:46 AM UTC
and my holding device. One of these days I might just get the hang of this computer lark
JMartine
KitMaker: 1,698 posts
Posted: Friday, October 31, 2008 - 02:45 PM UTC
Hey mate, looking good there!
I also "solved" my pics problems by using Photobucket for the WIPs and pasting the IMG link, and then using my space in here for the final product. cheers!
Posted: Friday, October 31, 2008 - 09:46 PM UTC
Community Build Session 5 Closed~Keep Modeling!
Posted: Saturday, November 01, 2008 - 11:35 AM UTC
Seams as though there are more problems
beefy66
KitMaker: 971 posts
Posted: Sunday, November 02, 2008 - 03:10 AM UTC
Thanks for all the help with the photo,s I,am greatfull that somebody is here to assist cos I,am not that good with these thing as you can tell
beefy66
KitMaker: 971 posts
Posted: Wednesday, November 26, 2008 - 01:56 AM UTC
here is a start to this months WIP first I have done the Air Arm Harriers and Seaking .Although you might not can tell the Harriers are two tone Light gray for the under side and dark gray for the Top side
I have done the cockpit canopys and windsheild on the air craft by using an artists fine line pen to give me the blue tinted tinge to the glass. Next step will be to seal the paint and add the decals.Next step for the flight deck is to mask the runway stripe and paint the deck a faded dark gray.
Well things have gone a lot better this month so far with the build only little bits done but geting there.Mark and Kenny thanks again for sorting out the images last month for me
beefy66
KitMaker: 971 posts
Posted: Thursday, November 27, 2008 - 12:19 AM UTC
Well I thought it was going better but have the pics did not come through so try again.
[imghttp://gallery.kitmaker.net/data/22114/Picture_1422.jpg][/img]
masking off the waterline with strips cut from wider tape
more work on the superstructure painting the deck dark gray
And painting of the flight deck.One day I might get the hang of this
peterf
KitMaker: 426 posts
Model Shipwrights: 424 posts
Posted: Thursday, November 27, 2008 - 12:56 AM UTC
Good progress, Keith, and as I said originally it's good to see this kit disected as it looks great in the box but as you have found, always needs some adjustment to make it fulfill your envisaged final appearance.
keep it going, I'm enjoying your journey.
Tailor
Posted: Thursday, November 27, 2008 - 10:42 PM UTC
Nice going Keith!
Guido
Guido
Posted: Sunday, November 30, 2008 - 09:58 PM UTC
Session 6 closed~Keep Modeling!!
Karybdis
KitMaker: 846 posts
Model Shipwrights: 740 posts
Posted: Monday, December 01, 2008 - 04:40 AM UTC
Great work, Keith and I agree with Peter. It's good to see this kit actually being built as first impressions in the box were one thing... You're doing wonderful work.
JMartine
Posted: Wednesday, December 03, 2008 - 12:37 PM UTC
really nice job Keith! specially on the birds.. nice detailing! cheers mate
beefy66
KitMaker: 971 posts
Posted: Friday, December 12, 2008 - 01:39 AM UTC
Well have had some enforced time off work this week and have been busy in the model room. I have painted the anti foul under the water line and re-done the sides
masked off the boot top
[imghttp://gallery.kitmaker.net/data/22114/Picture_1442.jpg][/img]
painted the anti-foul red
Mascked the lower hull and re painted the sides.
more to follow
more to follow
beefy66
KitMaker: 971 posts
Posted: Friday, December 12, 2008 - 01:59 AM UTC
Here have removed all tape and hull is now on correct base
[imghttp://gallery.kitmaker.net/data/22114/Picture_150.jpg][/img]
