G'day everyone.
Time for an update. It may seem I have been bludging on the modelling front lately, but circumstances keep getting in the way of me making progress with the mighty Tico..
Here is the PE for under the front of the flight deck. The ladders connect with the catwalks that were installed previously (I hope).
And this is the cat walks at the rear of the flight deck.
Before I attached the three piece main deck to the rest of the hull I had to make a small mod to the forward part of the deck to correct a small boo-boo by Trumpeter with CV-14. I started by cutting with the good 'ole razor saw but it quickly got very painfully slow. I then remembered I had bought a set of photo-etch saws for my rotary tool a few years ago and never used them
I opened the pack and was surprised to find there was a holder in the set for the blades as well. The saw made very short work of cutting the plastic and impressed me mightily with the lovely clean cuts after I reduced the speed a bit to stop the cut plastic melting.
Eduard supply this part as a guide to wear you have to cut,
and I applied the rest of the PE to the area after gluing this part in position.
After installing those pieces I decided it was time for the decks to go on. It is so big that I couldn't get it in the viewfinder so the ship looks small.
All clamps on deck!!
And finally..
This is the forward elevator.. I think I may position it a little down with a plane on it and the rails up to protect the crew from falling in the big hole.
That's it for now.
Warren
