Well the second day of 2014 is almost over and I have got a little further today after a number of setbacks, all of which where not caused by me, but by a set of PE instructions, and some PE that just doesn't fit as supplied.
First up, this is the bow of one of the cutters, and it is supposed to have etchong on it to simulate wood planking. Problem is the etch has not worked properly and there are only partial planking as you can see from the following photo..
Then the real fun began! The etched pieces provided by WEM to simulate interiors on the motor-launches plain don't fit even closely. This is surprising as most WEM stuff I have used over the years has been great.
Here is what the pieces look like all bent up and ready to be installed..
See the sides, they are about three times too high to allow the pieces to fit in the hulls. The only way I got around the problem was to cut most of the sides off with some PE scissors and re-bend them. The sides end up being less than 1mm high. The they almost fit very well. You also have to scrape out the insides of the hulls or they still won't fit. The hulls end up very thin. SO here is a Trumpeter plasyic launch..
Too this I also added the rudder and prop supplied by WEM..
But I didn't put the railings on the tops of the cabins as in my 'umble opinion guv there is jut not enough surface to get a big enough area to get glue on the attach the railings without flooding the area with glue.
So, again, I eventually got one of the interiors in place after about 3 hours of puzzlement. That is the one second from the top..
The top one is one without the interior parts, the third one down is just showing the prop/rudder again and the bottom on os one of the cutters which, unfortunately, the thwarts etc do not fit properly either.. Pity really. Also, if you are reading this Mr WEM, your numbering in places in your instructions is rubbish.. The boat is not A17 and the pieces for one of the boats is not 122..
Then we come to the 8 barrel pom poms. Do not follow the WEM instructions for these because if you do you will not be able to get the frame pieces over the ammo boxes. Put the frame pieces in place first then attach the details to the ammo boxes. I learnt this the hard way and had to remove all the ammo box detail to put the frames in place.
Here are a front and rear view of the pom poms..
Looks like I need to do the ammo box details again. Sometimes the macro lens can be helpful.
But that is enough for today. I don't like being negative but it is better to tell all you good readers the truth and let Mr WEM fix up the problems than gloss stuff over and have you cursing me when you come to the same spots when building your Belfasts.
Warre
