Thanks guys for all the kind comments, they're much appreciated.
Well a bit more progress.
I put a cover on the hull to protect from my wandering fingers.
I have started on the hullside etched. First the fixing points for the torpedo net booms. Tricky little blighters! The hull attachment point has a split pin arrangement to allow the boom to move. Trying to split the pin with the tip of a no. 11 blade was, well plenty of this
Thankfully only a couple were lost and the Pontos extras covered that. Eight each side.
Then on to the torpedo net shelf, looks pretty but..
Here Pontos have been a bit naughty. The booms are meant to rest in the gaps when in the stowed position, like this
but only two of eight on each side will actually do this because the shelf supports interfere with the boom e.g.
I guess it is standard for Pontos to use photos as instructions, so they show the shelf as to be installed but only with the booms extended, in another photo of the guns though they show the booms stowed and if you look closely you can see they have just cut off the offending shelf supports. I guess that is one way to fix it
More brass to come.
