There are several more folded boxes so I assume I will have the same problem with them, that is problem one with the eduard set number two the instructions show 2 part 30 and there are indeed two boxes on the deck which need those parts here is what eduard supply
As you can see only 1 part 30 and of course as I've already mentioned earlier in the build there are no where near enough scuttles supplied.
Number 3 their numbering on the frets has no logic at all number 84 being next to number 172 171 being next to 80 takes longer to find the part than it takes to atattch it.
Number 4 the folding instructions are pretty much non existent.
I've not had a lot of experience with pe but considering eduard are up there with the priceyest. I have to say it's the worst I've used so far. I think I will stick with mk1 and pontos from now on.
