Thursday, December 11, 2008 - 06:13 AM UTC
Adding to their growing U-Boat accessory range Griffon Models are releasing their 1/144th German U-Boat Type VIIC - Metal Torpedo/Periscope/2cm + 8.8cm Barrels update set. .
The product reference for this set is GRM N 14401.
This set is expected to be available in January 2009 and with a price to be advised.
This brand new accessory set is primarily designed for use with the Revell 1/144th German U-Boat Type VIIC 05038 kit.
Join me in viewing the preliminary shots of this set.
Kit features:
Images courtesy of Griffon Models
Kit features:
- Detailed 8.8cm SK C/35 Deck Gun + Metal Barrel;
- Detailed 2cm C/30 Flak + Metal Barrel;
- Metal G7a / G7e Torpedo;
- Full Detailed Torpedo Loading Gear (Optional);
- Metal Control Room Periscope;
- Metal Attack Periscope + Basement;
- Detailed Conning Tower;
- Detailed Front/Rear Deck;
- Detailed Net Cutter;
- FuMB-1 “Metox” Aerial “Biscay Cross” (Optional);
- Torpedo Display Rack;
- Auxiliary Material: ABS Rod, Copper Wire;
- Decal sheet.
Only 1 reader has rated this.
THIS STORY HAS BEEN READ 6,508 TIMES.
| Griffon Model Reviews | MORE |
| 1:144 Uboat Type VII-C/D PE by Anthony Kochevar | of 2 ratings, 100% found this helpful | |
| 1/72 Schnellboot S-100 PE Set by Dariush | of 1 ratings, 100% found this helpful | |
