1⁄72
Monday, May 25, 2009 - 12:31 PM UTC
Adding to their growing product range Griffon Models are releasing their 1/72 WW II German Schnellboot S-100 Class w/2cm Flakvierling 38 Premium Edition update set .
The product reference for this set is BPN 72002.
The emphasis is certainly on “premium” this looks to be a very comprehensive kit indeed.
This set is expected to be available shortly with a price to be advised.
This brand new accessory set is primarily designed for use with the Revell 1/72 S-100 05002 Series kit.
Join me in viewing the preliminary shots of this set.
Kit features:
Images courtesy of Griffon Models.
Kit features:
- Fourteen photoetched Frets ;
- Two Resin Foredeck Cowl Vent;
- One Resin Main Body for Bow 2cm MG C/38;
- Two Turned Aluminum 53.3cm Torpedo G7a;
- SevenTurned Brass Barrel for 2cm MG C/38;
- Auxiliary Material: Styrene Rod ,Copper Wire;
- Optional Mast with FuMB24 & FuMB32 Radar Detector Antenna;
- Detailed Mine Rails/Depth Charges Rack/Extra Torpedo Cradles;
- Armoured Bridge for Distinct S-100 Class Second Type Kalotte ( Skull Cap Bridge Covering) w/Hinged Armoured Doors for Wheelhouse;
- Rework Bow Flak Tube Cover;
- Option to Rework the Port/Starboard Torpedo Tube Door Open.
Only 1 reader has rated this.
THIS STORY HAS BEEN READ 7,227 TIMES.
| Griffon Model Reviews | MORE |
| 1:144 Uboat Type VII-C/D PE by Anthony Kochevar | of 2 ratings, 100% found this helpful | |
| 1/72 Schnellboot S-100 PE Set by Dariush | of 1 ratings, 100% found this helpful | |
