1⁄72
Tuesday, May 26, 2009 - 12:54 PM UTC
In another attempt to provide the model shipwright with a true product choice Griffon Models are releasing their 1/72 WW II German Schnellboot S-100 Class w/2cm Flakvierling 38
update set. .
The product code is N 72002 and you will see from the kit features listed below is a different set from the “Premium Edition”.
This set is expected to be available shortly and with a price to be advised.
update set. .
This brand new accessory set is primarily designed for use with the Revell 1/72nd S-100 05002
Series kit.
Join me in viewing the preliminary shots of this set.
Kit features:
Images courtesy of Griffon Models.
Series kit.
Kit features:
- Nine photoetch Frets;
- Two resin Foredeck Cowl Vent;
- A single resin Main Body for Bow 2cm MG C/38;
- Three turned Brass Barrels for the 2cm MG C/38;
- A single turned Brass Barrel for 3.7cm Flak M42;
- Auxiliary Material: Copper Wire & Styrene Rod;
- Armoured Bridge for Distinct S-100 Class Second Type Kalotte ( Skull Cap Bridge Covering) w/Hinged Armoured Doors for Wheelhouse;
- Optional Mast with FuMB24 & FuMB32 Radar Detector Antenna;
- Add Details on the Aft-Deck 2cm Flakvierling38.
THIS STORY HAS BEEN READ 7,108 TIMES.
| Griffon Model Reviews | MORE |
| 1:144 Uboat Type VII-C/D PE by Anthony Kochevar | of 2 ratings, 100% found this helpful | |
| 1/72 Schnellboot S-100 PE Set by Dariush | of 1 ratings, 100% found this helpful | |
