1⁄35
Wednesday, February 17, 2010 - 10:33 AM UTC
If you are currently building or intending to construct the mighty 1/35th scale Italeri Schnellboot S-100 kitset then the latest announcement from Master-Models maybe the answer to some of your detailing challenges.
Piotr Czerkasow of Master-Model has just announced the release of their latest addition to their range 1/72nd Sea Master Series Schnellboot Type S-100 armament gun barrels set .
This set is primarily designed for the 1/35th scale Italeri Schnellboot S-100 and appears to include turned brass/aluminum barrels with drilled and slotted flash hiders.
We understand that this set will be straightforward to use the instructions state “simply cut off the original plastic barrel and drill a hole in the remaining plastic parts and insert the metal barrel using Cyanoacrylate adhesives.”
What could be easier for the modelshipwright?
Look out for the next update to follow on some 1/350th scale releases from Master-Models.
Images courtesy of Master-Model.
Only 1 reader has rated this.
THIS STORY HAS BEEN READ 5,737 TIMES.
| Master Reviews | MORE |
| Naval Barrel Replacements by Todd Michalak | |
| Bofors 40mm by Todd Michalak | |
| HMS Roberts Armament by Todd Michalak | |
| Russian Cruiser Varyag Barrels by Dariush | of 1 ratings, 100% found this helpful | |
| Mast & Yards for Zvezda Varyag by Dariush | of 3 ratings, 100% found this helpful | |
