Seam Line Removal, 101
3
Method 2 :
If there is an area(s) on your build that is too small to get any sanding implements into, make sure that the gap is evenly filled (as before) and take a sharp blade and gently slice away the glued area until it has completely gone.
Below is a picture of how my piece ended up. If you cut too deep, add some putty to build the area up flush again, and gently re-cut the piece with the sharp knife. If you have one visibly flat area where you shave off the glue, gently rub the blade in a wider area to even out the shape better. If possible, sand with a fine grit sandpaper to get rid of the uneven edges.
Good stuff for a 101 series. Nice and clean and direct, well done (and good website, "Ghost")
APR 28, 2008 - 12:28 AM
Excellent article and photos! You made the process very clear and easy to follow!
APR 28, 2008 - 10:57 AM
Very nicely done, and good for hobby re-turnees or newbies. Bookmarked and looking forward to more! Thanks for posting, cheers
APR 28, 2008 - 01:42 PM
Copyright ©2021 by Scott Taylor. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2008-04-28 00:00:00. Unique Reads: 11485
