Seam Line Removal, 101
3
"Scott Taylor (RedComet) shares the first in a series of articles of general modeling tips and techniques, Step-by-Step style, that he has written and developed. This first one, Seam Line Removal 101, covers the basics of smoothing and removing the un-sightly seam lines when joining two pieces of plastic together, and can be used in all genres of the hobby
Removing seam lines from your built kits is pivotal in the overall finish of a model. Manufacturers have always had a habit of putting seams where they are most visible on a kit, hence a need to remove them from view. In this tutorial, I will demonstrate 3 different methods I use to remove seam lines from my kits.
What you will need :
1.) The piece you are planning on removing the seams from.
2.) Sanding supplies. In this case, I have a fine nail file and some sanding pads (1500 and 1800 grit to be specific).
3.) Some glue to join the parts.
4.) Some basic type putty to act as a filler / leveller for those bad joins.
Good stuff for a 101 series. Nice and clean and direct, well done (and good website, "Ghost")
APR 28, 2008 - 12:28 AM
Excellent article and photos! You made the process very clear and easy to follow!
APR 28, 2008 - 10:57 AM
Very nicely done, and good for hobby re-turnees or newbies. Bookmarked and looking forward to more! Thanks for posting, cheers
APR 28, 2008 - 01:42 PM
Copyright ©2021 by Scott Taylor. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2008-04-28 00:00:00. Unique Reads: 11484
