8
Internal Hanger and Hull
I decided to cut off the backs of the hangers on the rear of the decks and build the internals of these areas using the book as a reference. Carefully using a Dremel cutting disk and hobby knife I gradually cut away the backs of the boat and plane hangars I then made the hangars out of styrene sheets test fitting often until I got the right fit. Tracks were made out of stretched sprue and glued down per reference to the Yamato book. The boat hangars are too small for internal details, but the plane area will be set aside and finished later before it is glued in place. The rear hatches were drilled, shaped and an inclined ladder added for extra detail.The flight deck grills and supports were cut off and replaced with the Tom’s Modelworks photoetch parts. Porthole blanks were styrene cylinders sliced thin, there was no reference for placement in the book for these so I did a combination of what looked good and what other modelers had done online. Porthole eyebrows were made out of thin wire coiled around a small drill bit and cut in half. The part with the catapult turrets was glued in place, puttied and sanded smooth.
Parts for the side tunnel boat launches were also glued on. Stretched sprue filled the seam nicely and added better degaussing cable detail. I continued adding blanks, drilling out portholes and adding eyebrows to the rest of the model. The cable reels on the deck and part B15 were notched carefully on both sides to remove their “mailbox” like appearance. Any major alterations to the model need to be completed now without the risk of damaging fragile photoetch later on. Check the model carefully and fill and sand smooth any seems between parts.
Frank
JUL 20, 2008 - 02:36 AM
Hi Anthony
Congratulations Anthony!!!
JUL 20, 2008 - 09:12 AM
Thank you for sharing!
JUL 20, 2008 - 02:50 PM
JUL 20, 2008 - 04:51 PM
JUL 22, 2008 - 11:24 AM
JUL 22, 2008 - 12:59 PM
Thanks again
JUL 23, 2008 - 12:54 AM
