8
more details...
Mast: The mast was assembled and the type 13 radars removed. Tom’s Modelwork’s ladders were placed per instructions and book references. The platform was created with tread plate. Due to the scale of the ship it needed placed higher than was originally on the real ship. The smaller braces were made with stretched sprue. Part A21 was omitted and the bottom portion of it was made with styrene.
Finishing up: Now that all the main components were completed I went through and created several small details using various materials. Wire was used for the barrel guards. These were to prevent the guns from maneuvering to a position that would allow them to fire into the ship itself. They were test fitted several times before gluing. Various platforms, antennas and other items were fabricated using stretched sprue, styrene or paper. All shielded AA guns were completed then glued in place.
I had originally intended to have this be the finished superstructure but after a close examination of the book I was using for reference, I decided to make some more improvements. I noticed I had missed two portholes on ether side of the front molded-on fire control tower and added them. I also created the “U” shaped areas on the rear bridge platform out of styrene strips and added them. The funnel also looked a bit plain. I took the top part of some Tom’s Modelworks railing off leaving some of the poles on it and curved it then glued it into areas of the funnel to simulate the one bar rails that cover sections of it. It was over scale but still looked good.
The Gold Medal type 13 radar was also removed and a Lion Roar version that comes with several of these radars was added in their place. They had a more three dimensional look to them. At this point the superstructure was ready to be painted.
Other Deck Details
A few other deck details were crafted at this time. The most notable is the pipe that sits between the rear secondary turret and Main Turret No. 3. Various shapes and sizes of styrene and paper were used for all these details. Everything was then mounted in drill holes or on looped painters tape for painting with Tamiya IJN Kure Grey spray paint.
Frank
JUL 20, 2008 - 02:36 AM
Hi Anthony
Congratulations Anthony!!!
JUL 20, 2008 - 09:12 AM
Thank you for sharing!
JUL 20, 2008 - 02:50 PM
JUL 20, 2008 - 04:51 PM
JUL 22, 2008 - 11:24 AM
JUL 22, 2008 - 12:59 PM
Thanks again
JUL 23, 2008 - 12:54 AM
