Gentlemen-
Thank you for your kind comments.
@Jan
Those splashes along with spray and all are certainly among the hardest to do. I do agree with you that it looks kinda odd, but I reckon these splashes can’t be done much better. Maybe there is a way of using cellophane foil, Acrylic gel and a lot of patience to build them?
All the aspects for your kit and display are great (as usual - exclamation mark), but I wonder, if it would help the impression if you add a second, parallel run on splashes, if made from the wing mounted MGs. It does not have to run through the centre, but close to the edge of your display. Secondly, from looking at it, it does not seem that the bullets run in a straight line. Of cause in reality these may not be in a straight line either, but I think that the eye will be more pleased to see what it may expect.
I’ll guess we get to see the crew bailing out?
____________
I have been using the weekend for some more modest progress. I finished painting the hull and gave it a coat of Revell dull coat. It isn’t exactly dead-flat, but the slight sheen seems just right for scale effect.
After a day of drying, I applied a black wash of oil paint. First time I do that to a ship model, to keep on my resolve to try something new with every build. Here the wash it still wet, which makes it kind of prominent in the pictures:
I plan to apply another coat of dull clear coat, which should blend the dirt effect of the wash with the background, shouldn’t it?
As oil washes need notoriously long time to dry, I was getting ready to continue with the base, but I wasn’t in a mood for all the dirt with the styrofoam, so I started with the finishing gear.
First I took estimation and relative photo-measurement to create paper templates. By cutting out these and holding them to the model I was able to establish proper dimensions.
Another print of the properly sized template is then glued to the cutting mat. I cut length of .8mm and .5mm styrene rod (Lion Roar and Evergreen) to length and tagged them to the paper using Humbrol’s “Maskol”. Thus fixed in proper positions, I applied glue to the connecting spots. I let it dry for 12 hours to ensure to not cause any damage upon removal of the parts from the backing paper.
After confirming the dry-fit, I add some bits and pieces from the spares box to. I start with the longer part of the gear, which will be suspended over the weather deck. This part is now ready for painting.
Next will be the forward gear or the base. I don’t know yet. When turning to the base I will finally be where the campaign topic is actually located. (Finally!)
Guido
