Gentlemen –
Good going there! Nice to see some action from you guys. Keith: go slow and careful with the gaps. Every minute spend in clean assembly will be rewarded.
I’ve been pretty busy again, so the progress on the project is kind of slow.
After shaping the wave, I added a frame from 3mm plastic sheet. It’s some kind of recycling material so it was quite cheap. Again, trying something new saved me a lot of money, as using Evergreen would have cost a lot more than the 1.95€ I had paid for a 50x30cm sheet.
In a next step the whole scenery was painted with thick layers of acrylic gel. When you take your time, the gel starts to set while you work. That gives you chance to sculpt structures and wave patterns. I used the gel to make the gap between the frame and the Styrofoam vanish, too.
After some days I got back to the base and found that the crest had sagged while setting. So I added another layer for the crest.
After another day of drying I, smoothed over the edges of the frame and primed he while assembly. I used a primer usually used for figure painting. I found that stuff excellent for application of acrylic artists paint and it’s quite a bit cheaper than Mr. Hobbies product.
Drying time again – I did go on a bit with the outriggers, but haven’t taken photos, yet.
With the primer fully dried I took out the usual selection of acrylic artist’s paints - black, white, dark green and three shades of blue – and my trusty, stiff-bristled brush.
Now, I will be basically repeating the steps already shown in my build-up report on the Leipzig during the build-up contest. First everything gets covered in black. Then I add blend of black and some blues. I used a camera flash to make his visible, so don’t trust the colours.
Then I add green and white blended towards the crests and fading out towards the trough.
Letting the whole show rest for an hour the paint dried sufficiently to start dry-brushing starting with dark greys with a think of green to very very light grey. I have not used any clean white.
Satisfied with the result so far, I started painting the frame with my airbrush using WEM’s Cowl Black Satin colour coat.
TBC
Guido
