Hallo Guido!
Interesting method (another one)!
This Campaign is about to become THE water tutorial!
Keep up
"Divine Waterline"
Posted: Tuesday, November 24, 2009 - 04:35 AM UTC
CaptSonghouse
KitMaker: 1,274 posts
Posted: Tuesday, November 24, 2009 - 06:48 AM UTC
The wedding ring bit was the funniest thing I've read on this entire site!
--Karl
--Karl
Posted: Tuesday, November 24, 2009 - 07:25 AM UTC
The wedding ring bit was the funniest thing I've read on this entire site!![]()
--Karl
Oh NO Karl!
Not to be taken light hearted! Guido is being a true friend with his advice...
SWMBO in fury over a missing wedding ring... Run for your lives!
CaptSonghouse
Posted: Tuesday, November 24, 2009 - 08:48 AM UTC
Quoted TextThe wedding ring bit was the funniest thing I've read on this entire site!![]()
--Karl
Oh NO Karl!
--Karl
Tailor
KitMaker: 1,168 posts
Model Shipwrights: 676 posts
Posted: Wednesday, November 25, 2009 - 12:18 AM UTC
Glad you like it!
Modelling is supposed to be fun, isn't it?
Trying to write entertainingly should be a pricipal goal.
Cheers, mates!
Guido
Cheers, mates!
Guido
Tailor
Posted: Wednesday, November 25, 2009 - 03:26 AM UTC
Gentlemen,
I continue the water making process.
I had smoothed over the edges of the frame of the seascape and glued it to the base board. This needed time to dry. When ready I filed the gap between the frame and base board with white glue and primed the whole assembly using a fine primer usually used for figure painting. I had nothing else at hand and it worked out fine. It took only about 30 minutes to dry so could start to paint quickly.
First I painted the holes scenery blue.
Then I added a few dark Blue areas to break up the uniform blue. I made sure that the colour got into every recess on the surface. I let this dry before adding blue-grey all over making sure that this colour would NOT go into the recesses. This is easily achieved by making sure to use the paint undiluted right from their tubes.
I didn’t let the grey dry fully before adding consecutively lighter shades of grey with a tint of green in dry-brushing method that would only allow the paint to stick to the most elevate parts of the surface. Tiny bits of darker shade were added to the wakes of the running boat.
I taped off the frame and the cut-out for the Tripartite’s hull and added regular, transparent Silicone from the hardware store. In the following you need to proceed quickly, because after some 10 minutes the Silicone starts setting impeding your efforts. The silicone was spread out to create a layer 2 to maximum 3mm thick.
You will feel that the Silicone is a real b**** sticking to everything and being easily pulled up into long strands. That certainly doesn’t do! To create an even surface you need to apply diluted acetic acid. (Wear eye protection and do not overly try to inhale it, it’s not really healthy!). Where ever the acid touches the silicone it won’t stick any more. You can use your fingertips to smooth over the surface and remove the pulled up strands. Since this process that has to be done quickly I didn’t take and photos.
30 minutes later you can remove the tapes and make a dry fit.
I painted the cut-out black and applied a liberal amount of silicone along the rim.
Now I place the hull into its bed and use a fine spade to add more silicone as need to blend the hull into the seascape.
The create bow and stern wake I pulled off strands of cotton from cotton sticks and mashed them up in silicone. Then the are put into their places and shaped as desired.
Now with a nice back-drop (courtesy of Jim Adams: Thanks mate!) The seascape is basically finished. Of cause I still will have to paint the frame and base board, but that’s it.
I like this particular method because of the real “depth” of the water. As well, the water is very shiny and its sparkle changes as you change your relative position. It’s anther method most effective for shows. BTW: If thoroughly dried you may remove the silicone to change the painting underneath, but then you have to use a new layer of silicone.
This was the second of my preferred method. It’s called “modified “Ilse Water”” after Frank Ilse from Hamburg. His original method was developed for waterlined hulls.
Certainly I will be able to show a third method before the campaign is over and maybe – if lucky- a fourth.
Guido
Guido
Posted: Wednesday, November 25, 2009 - 04:10 AM UTC
Hallo Guido!
Interesting technique...
But I must say (at least from the photos) that the sea color/color treatment that you made looks a little strange... too much light grey?
Again could be the lighting (?)
I must also say that the effect of the silicone is something that I am considering trying one of these days
Danke
Danke
goldenpony
Posted: Wednesday, November 25, 2009 - 04:38 AM UTC
Guido
That sunrise does look good. Glad I could help!
Tailor
Posted: Wednesday, November 25, 2009 - 07:29 AM UTC
Hallo Guido!
Danke
Hardly the lighting...
Probably it is the grey!
Posted: Wednesday, November 25, 2009 - 10:01 AM UTC
For those of us who (unlike me) don't have easy access to tons of Acetic Acid, would regular vinegar do? Whilst Acetic is a relatively weak acid, its not something that I would want being chucked around the workshop on a regular basis!
BTW, I agree with Skipper, the base does look very light
Tailor
Posted: Wednesday, November 25, 2009 - 06:53 PM UTC
Neil,
Indeed vingar will do, if it isn't too much thinned down. The diluted acetic acid I use is from the supermarket. Here you may find in the same corner as cleaning agents. It is used to remove lime stome in baths and kitchens.
The light effected is indeed wanted. The light effect should replicate the feel of being able to see the bottom of the sea as you may in costal areas with water depth up to 15-20 Meters. I guess the look is a bit strange sure to the underlying blue it is a bit too intense.
I will decide if I go back remove the silicone and paint again.
Guido
Guido
Tailor
Posted: Thursday, November 26, 2009 - 12:02 AM UTC
This is about what I have been aiming at...
I'll use more green in the white next time around!
Guido
Guido
CaptSonghouse
Posted: Friday, November 27, 2009 - 07:30 AM UTC
You know, that is the tricky thing about water, isn't it? It can be a variety of colors at the same time, depending on your viewing angle. I bet if that scene shown above were viewed from an aircraft, the colors of the water would be different.
--Karl
--Karl
beefy66
KitMaker: 971 posts
Model Shipwrights: 645 posts
Posted: Monday, November 30, 2009 - 08:33 AM UTC
Here is my finnished RNLI Severn Class Lifeboat hopefully my photo skills are getting better.I have finnished the base off with some thin pine wood and stained and varnished
Any comments welcome always wanting to learn from my mistakes
ajkochev
KitMaker: 246 posts
Model Shipwrights: 221 posts
Posted: Monday, November 30, 2009 - 08:50 AM UTC
That lifeboat looks good to me and so does the water. I cannot see any weathering on the boat but that might not be an issue with this type of boat, if it was well taken care of.
Good job ether way.
Good job ether way.
MrMox
KitMaker: 3,377 posts
Model Shipwrights: 985 posts
Posted: Monday, November 30, 2009 - 08:59 AM UTC
A very dynamic setting, that really ads to the boat.
Likewise, I cant see any weathering, but these boats propably recieves a lot of spit and polish !
Good work - any chance for a crew figure ?
Cheers/Jan
Cheers/Jan
beefy66
KitMaker: 971 posts
Posted: Monday, November 30, 2009 - 09:01 AM UTC
No wheathering they are well looked after boats here is my local one at Tynemouth
Posted: Monday, November 30, 2009 - 10:38 AM UTC
Hi Keith!!
Looks terrific! I really like the theme and your rendition too!
Just a question regarding the RNLI model.. did Airfix included any crew members?
I understand that they are inside most of the time, but I have to ask!
Congratulations Keith
Tailor
Posted: Monday, November 30, 2009 - 06:42 PM UTC
Great result, Keith!
I really like it! Well done, mate!
Guido
Guido
JimMrr
KitMaker: 1,505 posts
Model Shipwrights: 409 posts
Posted: Tuesday, December 01, 2009 - 01:50 AM UTC
That is very impressive water !!! and not to slight the boat either ...VERY impressive!
Frigate
KitMaker: 500 posts
Model Shipwrights: 205 posts
Posted: Tuesday, December 01, 2009 - 01:58 AM UTC
Gents,
We have some Great builds going here. My USCG MLB is progressing - but slowly. If I get a chance, I'll take a few shots this weekend, both to show the progress, and get any critiques anyone may have. Keep building, Gang. Bruce
Posted: Tuesday, December 01, 2009 - 05:48 AM UTC
Thats the money shot right there!
beefy66
KitMaker: 971 posts
Posted: Tuesday, December 01, 2009 - 06:09 AM UTC
Gents thanks for your kind words unfortunatly Airfix do not include any crew figures but I will be trying to convert some Revell 1/72 figures.At least give it a go to add to the scene
CaptSonghouse
Posted: Tuesday, December 08, 2009 - 07:50 AM UTC
Hi All!
Since I have been having issues getting photos to post on the forums consistently, I have opted to save up my WIP pics and submit them as a feature. My entry for Divine Waterline is the "Counter Blow" feature recently posted to the site. I have found a new use for a certain holiday item when depicting certain water effects as you will see.
--Karl
--Karl
Frigate
KitMaker: 500 posts
Posted: Wednesday, December 09, 2009 - 12:35 PM UTC
Karl,
Your technique is absolutely Great !!!! At least I think so. A question for you, the material used for the bursts, are you getting that in cloth shops ? I am really impressed with the effect you have achieved. Now I really have to get serious with my build ! Thank you for the tip, and the Great article...........................Bruce
