STEP 3-Bobstays
Longridge-Text page 226,Plan 6.
Hackney-Text page 61,figure 13.
Three bobstays are fitted between the head and the bowsprit.They are of 8" rope each one doubled and rigged by hearts and lanyards.The hearts are 14" long and the lanyards are of 4" rope.Two hearts are required for each bobstay.
Riggin'...online booklet
dolly15
KitMaker: 8,227 posts
Model Shipwrights: 451 posts
Posted: Friday, November 27, 2009 - 08:03 AM UTC
dolly15
Posted: Friday, November 27, 2009 - 08:07 AM UTC
Step #4
Bowsprit Shrouds:
Longridge P226 Plate 72 (excellent picture)
Hackney P62 Fig 13
Attach four 14" hearts to the bowsprit.Two collars of 8" rope each carry a pair of these hearts mounted one on each side of the bowsprit.
Bowsprit Shrouds:
Hackney P62 Fig 13
dolly15
Posted: Saturday, November 28, 2009 - 02:28 AM UTC
Step 5 Mainstay.
Longridge P220-21. Plan 8. Plate 74.
Hackney P62 .Plate 11.
Lead a length of 14" rope down through one of the two rear slots of the marines walk,down through the angled drilling in the knighthead ,through the large hole in the gammoning knee, up through the other knighthead and up through the other rear slot in the marines walk.Seize the two ends around a 26" heart .Then lead a length of 19" rope up through the maintop round the back of the masthead and down through the other side of the main top.Seize a second 26" heart in the free end.Lead this end down to the starboard of the foremast and reeve the two hearts together with 6" rope ,tying the end around the turns.
Please note:When the mainstay has been rigged attach a 16" single block to each side of its collar close under the main top just forward of the lower shrouds.These blocks will be used for the fore braces at a later stage.
dolly15
Posted: Saturday, November 28, 2009 - 02:58 AM UTC
dolly15
Posted: Saturday, November 28, 2009 - 03:13 AM UTC
dolly15
Posted: Saturday, November 28, 2009 - 03:40 AM UTC
Step 6 Main Preventer Stay.
Longridge P221-22.
Hackney P62 Fig 13
Install this above the mainstay in the same way as step 5,but placing the first length of rope around the bowsprit only and through the forward slot in the marines walk.Use 17" hearts and 13" rope for the preventer stay itself.
Longridge P221-22.
Hackney P62 Fig 13
dolly15
Posted: Saturday, November 28, 2009 - 02:29 PM UTC
Step 7. Forestay
Longridge P221-22 Plan 8
Hackney P62 Fig 45.
Using a 9 1/2" rope attach a 26"heart above the bowsprit just ahead of the aftermost bobstay.Place a length of 18" rope around the foremast head .Seize a second 26" heart in the other end and reeve the two hearts together with 6" rope.
Hackney P62 Fig 45.
dolly15
Posted: Sunday, November 29, 2009 - 03:55 AM UTC
Step 8. Fore preventer stay
Hackney P62 Fig 45
Longridge P222 Plan 8
Attach this stay above the forestay, use a 6 1/2" rope for the bowsprit collar just ahead of the middle bobstay,11 1/2" rope for the stay itself and two 16"hearts .Reeve the two hearts together using 4 1/2" rope.
Hackney P62 Fig 45
dolly15
Posted: Sunday, November 29, 2009 - 04:10 AM UTC
Step 9 Snaking
Hackney P62 plate 11 (excellent pic)
Longridge P222 Fig 151
Using a 2" rope snake together the forestay and the fore preventer stay.The snaking is continuous from just above the upper hearts to just below the knot where the stays divide around the masthead.It is tied around one stay ,taken to the other and tied around that then back again to the other and so on.
The mainstay and the main preventer stay should also be snaked the same way.
Note: the snaking could be done now or later but sometime before starting the running rigging.I like to leave it till later Why? because I don't permanently fasten down the standing rigging at this time but do it only when it is all completed.
This post was removed.
dolly15
Posted: Monday, November 30, 2009 - 04:20 AM UTC
Step 10 Mizzen Stay
Hackney P62 Fig 45
Longridge P222 Plan 6
Step 10 Mizzen Stay
Hackney P62 Fig 45
81/2 " rope set up from mizzen masthead and leading forward and down to tie in a loop around the mainmast.The other end then ties off to the deck eyebolt aft of the mainmast.
Hackney P62 Fig 45
Step 10 Mizzen Stay
Hackney P62 Fig 45
dolly15
Posted: Monday, November 30, 2009 - 04:33 AM UTC
Step 11 Mizzen Preventer Stay
Hackney P62 Plate 10
8 1/2 " rope ,rigged as for the mizzen stay but the loop around the mainmast is made a little more than halfway up the mast.The other end ties off to the eyebolt on the deck.
dolly15
Posted: Monday, November 30, 2009 - 04:45 AM UTC
dolly15
Posted: Tuesday, December 01, 2009 - 02:19 AM UTC
Step 12 Jeer Blocks, Fore and Main.
Hackney P62 Fig 41
Longridge Fore yard P241 Plan 8
Main yard P251
Jeer blocks are three sheave and they hang just below the level of the tops by means of a 7" rope loop around the masthead turns.These turns made first,are of 4 1/2 " rope passed six times round the masthead and through the mast cleat on the opposite side from the block,so forming a strop.These cross front and rear of the masthead.The jeers on the mainmast are 28" and those on the foremast are 26".
Hackney P62 Fig 41
Main yard P251
dolly15
Posted: Tuesday, December 01, 2009 - 05:01 AM UTC
dolly15
Posted: Tuesday, December 01, 2009 - 06:26 AM UTC
Step 13
Jib Boom Horses
Hackney P64 Fig 13.
Longridge 227,234 Plan 6.
Make a series of simple overhand knots in a length of 4" rope.Clove hitch the center of this around the outer end of the jib boom and tie the other two ends together around the jib boom behind the bowsprit cap.To look natural,allow the ropes to sag beneath the boom under their own weight .
Jib Boom Horses
Hackney P64 Fig 13.
dolly15
Posted: Tuesday, December 01, 2009 - 08:10 AM UTC
dolly15
Posted: Tuesday, December 01, 2009 - 11:07 AM UTC
]dolly15
Posted: Wednesday, December 02, 2009 - 08:10 AM UTC
Step 14
Topmast Pendants
Hackney P 64 Fig 21
Longridge I can't find a good reference for this step in Longridge.
It is a single pendant of the type seen on the mizzen mast.
I will however try to find a reference and post it here.
A single pair of pendants is fitted around each of the fore and main topmasts immediately above the crosstrees,in the same way as the mizzen pendant.They are 5 1/2" rope.There is no topmast pendant on the mizzen.
__________________
Topmast Pendants
Hackney P 64 Fig 21
__________________
dolly15
Posted: Wednesday, December 02, 2009 - 08:39 AM UTC
Step 15
Breast Backstays
Hackney P64
Longridge P231-32 Fig 162 (good drawing of the breast backstay purchase)
These are fitted to the fore and main topmasts only,one each side, they are 7" rope with an eye going over the masthead and a 14" block tied into the lower end slightly above deck rail level.A 5" rope is tied to the base of the first deadeye on each channel except the mizzen ones,it runs through the block,and ties off to the base of the third deadeye on the fore channels and to the base of the second deadeye on the main channels.
Breast Backstays
Hackney P64
