Riggin'...online booklet
dolly15
Quebec, Canada
KitMaker: 8,227 posts
Model Shipwrights: 451 posts
Posted: Thursday, December 03, 2009 - 12:18 AM UTC
Deleted posts and drawings.
I have deleted some posts here and on my photobucket .I have decided to use my pictures only.No drawings or other material will be used as this is available from other sources on the web.It is really only the sequence of rigging that is missing on the websites and besides my drawing are lousy.Thank you for your understanding ,I am kind of learning about what works and doesn't work as I go along too.
Cheers! John.
dolly15
Quebec, Canada
Posted: Thursday, December 03, 2009 - 04:36 AM UTC
Step 16
Fore Topmast Standing Backstay
Hack P64
Long P222
Three each side,of 7" rope.
____________________
Step 17
Main Topmast Standing Backstay
Hack P64
Long P222
Three each side of 7" rope belay to the foremost eye on the backstay stool.
dolly15
Quebec, Canada
Posted: Thursday, December 03, 2009 - 09:02 AM UTC
dolly15
Quebec, Canada
Posted: Thursday, December 03, 2009 - 09:50 AM UTC
Please note:
For large pics of the rigging please go to my photobucket.When on my main page scroll down the albums list on the port side.
Click on "Victory book" and there you will find large and very large pictures , in approximately the right sequence for rigging Victory.Remember these pics are of a 1/72 scale model blown up to make your job of rigging easier.Color,scale,small flaws and mistakes will be embarrassingly obvious to the expert but at scale distance to the ordinary modeler it looks fine.Remember this is a diorama and I did use some artistic license for overall effect.Anyway that's my story and I'm sticking to it!
dolly15
Quebec, Canada
Posted: Friday, December 04, 2009 - 03:45 AM UTC
The most important thing is the rigging sequence and that I can vouch for because when I finished I only had two pieces of running rigging that I couldn't place properly.I forget what they were now but because I no longer had access to the bottom of the mast I had to belay them to the shrouds.
After I finish the sequence of rigging I plan to identify the belaying points on the ship for each step of the rigging process that I am showing here.I plan to identify them by keying them to each step that I am working on now.The actual run of the rigging is covered very well by Longridge but he like all the others(except Hackney) is very confusing on the step-by step sequence,In other words the "how to..." of how the rig the ship in the proper order, which in this case happens to be how the real ship was rigged by her riggers at the time.Luckily for us as modelers it also happens to be the best method to rig a model. If you are not careful you can very quickly loose access to critical areas in all the maze of rigging.As a general rule I never permanently belay anything down until thinking it though.Sometimes it is tempting to want to completely finish a step without really thinking about it.A good example would be the shrouds ,do not finish them with laniards and ratlines until the end of the rigging process.You can finish them individually but leave the laniards(the ropes between the deadeyes} loose.I don't know how many times I had to free them to get access to the running rigging belaying points at the foot of the masts.The ratlines you will have good access to until the end so there is no rush to finish them.
It is very important to keep asking yourself "will I need future access to this area ?" and resist the temptation to "finish it " permanently.
dolly15
Quebec, Canada
Posted: Friday, December 04, 2009 - 09:24 AM UTC
dolly15
Quebec, Canada
Posted: Saturday, December 05, 2009 - 01:53 AM UTC
Please note:
There is one exception to what I said about rigging the ratlines and that is the area between the futtock stave and the deadeyes at the top.Due to reasons of accessibility the ratlines that run from the futtock stave to the masthead are best installed before the futtock shrouds.See:Longridge P229 Fig 157 and Plate 63.
When climbing the shrouds to the top most sailors would use the ratlines attached to the futtock shrouds instead of going up the safer way through the "lubbers hole".( "landlubber")
dolly15
Quebec, Canada
Posted: Saturday, December 05, 2009 - 02:32 AM UTC
dolly15
Quebec, Canada
Posted: Saturday, December 05, 2009 - 02:40 AM UTC
dolly15
Quebec, Canada
Posted: Monday, December 07, 2009 - 03:48 AM UTC
Step 18
Mizzen topmast standing backstay.
Hack P64 Fig 11
Long P222
One each side 4 1/2" rope leading to the forward eyebolt on the mizzen backstay stool.
dolly15
Quebec, Canada
Posted: Monday, December 07, 2009 - 04:02 AM UTC
Step 19
Fore topmast shifting backstay
Hack P64
Long P231
One each side 7" rope with a 12" double block tied to the lower end.12" single becket block tied to the foremost of the two eyebolts in rear end of fore channels.The blocks are joined by a 3" rope in a luff tackle,the fall being tied back on the eyebolt.
dolly15
Quebec, Canada
Posted: Monday, December 07, 2009 - 04:19 AM UTC
Step 20
Main topmast shifting backstay.
Hack P65
Long P231
Same as fore backstay but the lower 12" blocks are tied to the main channel eyebolts between the ninth and tenth deadeyes.
dolly15
Quebec, Canada
Posted: Tuesday, December 08, 2009 - 10:30 AM UTC
Step 21
Mizzen topmast shifting backstay.
Hack P65
Long P231-32
Same as the fore and main but using a 4 1/2" rope for the backstay and 9" blocks with the lower single one tied to the single eyebolt on the aft end of the mizzen channel.The blocks are connected by 2 1/2" rope.
dolly15
Quebec, Canada
Posted: Tuesday, December 08, 2009 - 11:09 AM UTC
Step 22
Foretopmast preventer stay
Hack P65
Long P222
Tie one 12 " single block to the base of the port knighthead.Tie one end of a 6 1/2" rope around the foretopmast head.The lower end is led through the hole in the port bee.A single becket block is tied to its end.The two blocks are connected with a 3" rope in a gin-tackle,with the fall around the knighthead.
Please Note:
that you have to jump around from one page to the other when following Longridge,Hackney however is consistently step-by-step.This is the beauty of Hackney's book.
dolly15
Quebec, Canada
Posted: Tuesday, December 08, 2009 - 11:28 AM UTC
Step 23
Foretopmast stay
Hack P65
Long P222
Tie a 12" single block to the base of the starboard knighthead.Rig the stay as in step 22 but using a 8 1/2" rope.Lead it through the hole in the starboard bee and connect the blocks with a 3 1/2" rope,belaying the fall around the knighthead.
dolly15
Quebec, Canada
Posted: Friday, December 11, 2009 - 02:45 AM UTC
dolly15
Quebec, Canada
Posted: Friday, December 11, 2009 - 03:33 AM UTC
My Reference Source for this thread is Hackney's book.
He lists his reference sources as the following:
Published
The Anatomy of Nelson's Ships
Longridge
HMS Victory;Building ,Restoration and Repair
Bugler
Unpublished
Admiralty rigging charts and deck diagram at Portsmouth Dockyard.
Observation
Detailed examination of HMS Victory in Trafalgar condition at Portsmouth Dockyard
Discussions with
The Captain and ship's company of HMS Victory
The Master Rigger and his staff at Portsmouth Dockyard
The Curator and staff of the Victory Museum
dolly15
Quebec, Canada
Posted: Saturday, December 12, 2009 - 06:12 AM UTC
dolly15
Quebec, Canada
Posted: Saturday, December 12, 2009 - 07:53 AM UTC
dolly15
Quebec, Canada
Posted: Saturday, December 12, 2009 - 10:53 AM UTC
Here is a better pic of steps 15 and 16.
dolly15
Quebec, Canada
Posted: Saturday, December 12, 2009 - 11:39 AM UTC
Note:The Topmast Backstays
The fore and main topmasts each have five backstays on both the port and starboard sides.The miizzen topmast has only two.
There are three types of topmast backstays,-Breast
-Standing
-Shifting
dolly15
Quebec, Canada
Posted: Saturday, December 12, 2009 - 01:07 PM UTC
dolly15
Quebec, Canada
Posted: Sunday, December 13, 2009 - 02:18 AM UTC
Fore Topmast Backstays.
The fore to aft sequence for rigging the backstays at the foremast port channel:
1-Breast backstay eyebolt-between deadeye 1 and 2.
2-Standing backstay 1-4th deadeye.
3-Standing backstay 2-10th deadeye.
4-Standing backstay 3-14th deadeye.
5-Shifting backstay-eyebolt just aft of 15th deadeye.
The foremast port channel is similar.
dolly15
Quebec, Canada
Posted: Sunday, December 13, 2009 - 05:52 AM UTC
Main Topmast Backstays.
1-Breast backstay eyebolt -same as foremast.
2-Standing backstay 1-same as foremast.
3-Standing backstay 2-8th deadeye.
4-Standing backstay 3-1st deadeye on stool.
5-Shifting backstay-same as foremast.
dolly15
Quebec, Canada
Posted: Sunday, December 13, 2009 - 06:11 AM UTC
Mizzen Topmast Backstays.
1-Standing backstay-1st deadeye on mizzen stool.
2-Shifting backstay-eyebolt at aft end of the mizzen channel.
