1/350 Fujimi IJNS Haruna build
Posted: Sunday, September 19, 2010 - 03:14 AM UTC
KitMaker: 887 posts
Model Shipwrights: 575 posts
Posted: Sunday, September 19, 2010 - 07:05 AM UTC
Very nice - could you tell me the full length of this model - the PE is looking great, and can't wait as this comes together.
Posted: Sunday, September 19, 2010 - 07:13 AM UTC
Thanks Alec, she's 25 inches long. The fun part of the build starts now after all the necessary paintwork on the hull has been done.
Julian
Posted: Sunday, September 19, 2010 - 05:13 PM UTC
I am hoping someone can help me out with the following question:
Before weathering the upper hull: what exactly are parts a and parts b.
Parts a look like pipes projecting through the hull and curved down, .
b looks some sort of chute to clear the hull, ( garbage chute?).
Julian
Hi Julian. I am having a stab in the Dark but they could be leftover reminders of her early Days when she was Coal Fired. I am guessing that they could be the Coal or Soot Shoots from from when she used to fill her Coal Bunkers. When Re-Boilered to Oil, I guess that they didn't bother removing and Plating over those Areas hence they remained in Place. I hope that will help answer your Mystery......Cheers Mark
Posted: Monday, September 20, 2010 - 06:02 AM UTC
Hi Mark, thanks for the message. It's plausible but would a powder be pushed down a pipe with a bend? How does this one sound: the pipes curve over the top of the torpedo bulges, (which were added later in the Harunas career I presume). Would this have been done to prevent the flow from the scuppers pooling on the top of bulges and enabling it to flow straight overboard? Does this sound likely or should I stop drinking the 96% alcohol paint thinner?
Julian
Posted: Tuesday, September 21, 2010 - 06:11 AM UTC
Pace has slowed down slightly due to the real world intruding
Fitting mushroom vents, mushroom vents and more mushroom vents so I couldn't resist fitting the first turret, just a test before fitting the PE to the turret:
Julian
Posted: Tuesday, September 21, 2010 - 08:19 AM UTC
#068
Zuid-Holland, Netherlands
KitMaker: 1,144 posts
Model Shipwrights: 172 posts
Posted: Tuesday, September 21, 2010 - 10:13 AM UTC
She is shaping up very nicely, I have to say...
The wooden deck looks better and better now the rest is being built up... Just wondering, since IIRC the Haruna is a sister to the Kongo, does it have the casemate issues that Fujimi's Kongo has or has that been fixed?
Harm
Posted: Tuesday, September 21, 2010 - 12:27 PM UTC
Wonderful progress Julian.
Posted: Tuesday, September 21, 2010 - 05:09 PM UTC
Harm, Kenny, thank you both very much. In answer to your question Harm: the casemate issue is the same as for the Kongo and would require major surgery to change. For me it's not a big issue but it evidently does poke "experten" in the eye
I'll try and post a couple of photos this evening so you can see how serious the problem is.
Julian
Posted: Wednesday, September 22, 2010 - 06:32 AM UTC
Ok, top photo is of a scale drawing of the Kongo. All casemates nice, vertical etc.
Photo number two is my Haruna build: not quite right:
Make your own judgement on how dreadful this fault is.
Lastly:
Turret "A" in base coat, weathering still to come
Julian
#068
Posted: Wednesday, September 22, 2010 - 06:42 AM UTC
Thanks for the images...
It is the first time I have seen images of the wrongly shaped casemates - and frankly it does look very odd indeed... and the turret in paint looks a lot better,,,,
Harm
Posted: Wednesday, September 22, 2010 - 07:19 AM UTC
Harm
It doesn't look very practical. I can't imagine a shipyard choosing this way to construct the ship, (nowadays with the stealth profiles okay, but not in 1912). Having written that I must say that if Dade hadn't mentioned it in his review of the Kongo I wouldn't have really noticed it. It depends on which road you follow: if you take the arduous path of the die hard rivet counter life will not be easy for you and nearly all models will contain nearly unsurmountable errors. If you choose to build a model because you want to blow of some steam after a hard day at the office and a Japanese battlewagon happened to catch your eye at model store, hey, you might even get around to enjoying yourself
Just my 2 cents Harm, not going to get my panties all bunched up about it
Julian
Posted: Sunday, September 26, 2010 - 01:59 AM UTC
Mississippi, United States
KitMaker: 106 posts
Model Shipwrights: 92 posts
Posted: Sunday, September 26, 2010 - 12:35 PM UTC
Jullian if I may what kind of MIG products and colors do you use?I have never used them before but here alot of people in all branches of modeling using them.Cheers
Posted: Sunday, September 26, 2010 - 05:17 PM UTC
Hi Kevin, I use MiG's filters, washes and effects, (rain marks, rust etc.) and the pigments, (although those are more use for armor). Paints are Vallejo, Life Color, Tamiya and Citadel. I also very occasionally use Humbrol enamel.
Julian
Posted: Friday, October 01, 2010 - 04:55 AM UTC
KitMaker: 106 posts
Posted: Saturday, October 02, 2010 - 12:50 PM UTC
Looking really good there Julian
these Japanese ships really had some nice lines in them.Is the shahing on the turrets chalks,pre-shade??
Posted: Saturday, October 02, 2010 - 06:55 PM UTC
Hi Kevin, yes, couldn't agree more. The Japanese had a fleet of very impressive and beautifully designed warships. The Kongo class has of course a very British pedigree to start off with.
The shading is not chalk or pre shading. I spray the "modules" with Tamiya Kure arsenal grey. Then I do a light spray on all surfaces with Kure grey lightend with some white. I finally add a Mig filter using the blue for panzer grey. On the hull sides I also did an oil wash using raw umber as coloring.
Julian
Posted: Sunday, October 03, 2010 - 01:47 AM UTC
Posted: Sunday, October 03, 2010 - 03:49 AM UTC
KitMaker: 106 posts
Posted: Sunday, October 03, 2010 - 10:10 AM UTC
Man got to get in on that MIG stuff just my patience for reading instructions lately has been really short.The girl is really looking fantastic Julian.I read another method in short discription of using oils on the deck;heavy;leave for 30minutes or so and then wipe.It had a nice effect of bring out the details of the planks.Ever been down that road Jules??I might try it out on a small part of the GS upper deck I tried one deal we do with A/C and I really did not like the effect so much.Cheers
Virginia, United States
KitMaker: 21 posts
Model Shipwrights: 20 posts
Posted: Sunday, October 03, 2010 - 11:26 AM UTC
What exactly do you guys mean by filtering?
KitMaker: 106 posts
Posted: Sunday, October 03, 2010 - 01:20 PM UTC
This is what I have found from MIG have not read itn all the way
http://www.migproductions.com/minisite/lavados/washes.htmJoined: October 30, 2005
Posted: Monday, October 04, 2010 - 06:04 AM UTC
Hi Kevin, Jason,
First of all thanks for the kind remarks about the Haruna build Kevin, I am enjoying the build and the results are okay up until now. Yes have heard about the oil wash technique you describe but I stick to my own way of doing the decks, (which is probably less realistic but reasonably predictable for me
Jason, Kevin has put Miguel's own explanation of the difference between filters and washes online via a link. I use it to get a weathered appearence in "munchkin scale" models. The filter is applied over a two tone spray job to bring things together and avoid a monochromatic appearence. It's something you have to mess around with to get happy with.
Check out these filters, washes, glazes and pin washes on my SU-150 build:
Julian
