Official "Big Fish" Campaign Thread
Posted: Sunday, February 27, 2011 - 05:48 AM UTC
Hi Jesper, you still have plenty of time yet. The Seehund is a nice base to work from
Julian
MrMox
Aarhus, Denmark
KitMaker: 3,377 posts
Model Shipwrights: 985 posts
Posted: Sunday, February 27, 2011 - 09:09 PM UTC
I "spot" a Biber thats beginning to look good
Good luck with the seehund, the large surfaces gives ample oppertunity to work with pre- and postshading and loads of filters.
Cheers/Jan
Posted: Sunday, February 27, 2011 - 10:23 PM UTC
Nice work Jesper & Jullian, both projects coming on great guns
A little progress from my side, base colour of grey sprayed fairly roughly onto the base.
Posted: Sunday, February 27, 2011 - 11:00 PM UTC
Thanks Simon, Jan,
I tweaked the camo a bit and have found a diver that I can use in a "bailing out" pose:
Julian
MrMox
Aarhus, Denmark
Posted: Monday, February 28, 2011 - 04:20 AM UTC
I think I am pretty much done with this build - I am going to see, if I can´t find some japanese looking figure to accompany it:
Posted: Monday, February 28, 2011 - 04:40 AM UTC
Magnificent build and weathering Jan. Black is a difficult color to model and weather but you got everything right here !
Julian
MrMox
Aarhus, Denmark
Posted: Monday, February 28, 2011 - 10:23 AM UTC
Thanks Julian, black is a color you dont want to look black ón a model
I have actually been working a bit ón the Biber cockpit - maybe i will get it done after all !
Cheers/Jan
Posted: Monday, February 28, 2011 - 09:35 PM UTC
Nice Work Jan, the weathering on the black is subtle and very effective.
I am sure I have seen that figure somewhere before Julian, looks effective though.
Posted: Monday, February 28, 2011 - 11:33 PM UTC
Yes, it's the getaway Italian
It does give an idea of the scale of the Beaver even if his equipment isn't accurate. Had to amputate his legs and grind down his bottom with a Dremel to get him to fit in the hatch opening. You will have his evil twin hanging around your dockside Simon
Julian
SGTJKJ
#041
Kobenhavn, Denmark
KitMaker: 10,069 posts
Model Shipwrights: 228 posts
Posted: Tuesday, March 01, 2011 - 12:59 AM UTC
Very nice build, Jan. As already pointed out the weathering is spot on.
Julian, nice correction on the camouflage.
Good idea with the guy bailing out even if he uses Italian equipment. A lot of strange equipment was sourced by the Germans from the Italians after their surrender in 1943. Everything from camouflage clothing fabric, hand guns to tanks. So a little scuba equipment is likely to be sourced from there as well.
I have added the base colour and a little grey green camouflage on my Seehund. I assumed that a darker disruptive camouflage would be effective to counteract the spray and bow waves when travelling on the surface. I like the way it looks.
However, checking on the few photos I have it seems like more white was added. That does not seem logical to me(?), but I am also a novice on sea camouflage.
Next are the decals and then weathering can begin.
The colour scheme for the Torpedoes confuses me a bit. According to the instructions they can be painted in a number of black, blue, red, steel, and brass combinations. I have no idea iof this is correct(?).
I have decided the make the torpedoes black with dark red explosive charge and brass screws and brass arming device in the nose. This is according to one of the suggestions in the instructions and it brings some nice colour to the model. Should any other details be painted on the torpedo?
More to follow
Posted: Tuesday, March 01, 2011 - 01:53 AM UTC
Hi Jesper, the Seehund is looking good there ! I think the idea of the camo would be to break up the shape of the submarine underwater when seen from the air. Surfaced the sub will pull a bow wave and prop wash that will be clearly visible from the air. I painted my ICM Seehund (1/72) in the grey scheme with white blotches on it. The torpedoes would probably have received a quick coat of grey paint for the same reason. I am going to give myself some leeway here though because I like the contrast between the submarine and the torpedoes, (have stepped away from historically correct camo here anyway so might as well go the whole hog now . ).
Julian
CaptSonghouse
KitMaker: 1,274 posts
Posted: Tuesday, March 01, 2011 - 08:13 AM UTC
...black is a color you dont want to look black ón a model
No truer words have been spoken.
--Karl
AlanL
KitMaker: 14,499 posts
Posted: Tuesday, March 01, 2011 - 08:19 AM UTC
Hi Guys,
Simon the Maiale looks great, dios coming along really well.
Julian, excellent Bibber.
Guido - class really interesting subject.
Jan, looking good.
I had entered for this with the Bibber but got finished much earlier than expected so it went into another campaign. Excellent looking builds folks, thanks for sharing.
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Tuesday, March 01, 2011 - 09:23 PM UTC
Thanks for the comments, Julian. You are probably right about the camouflage. In that case my camouflage should help break up the outline of the boat seen from the air although it might not be as effective.
Anyway, just as you I have also decided to follow the kit instructions on the torpedoes although in real life the torpedoes might have been camouflaged better.
The same process with the decal markings. As discussed earlier in this tread I think the decals in the kit are based on museum examples and not period photos, so also here I will allow myself some artistic license.
More to follow.
Tailor
Nordrhein-Westfalen, Germany
KitMaker: 1,168 posts
Model Shipwrights: 676 posts
Posted: Tuesday, March 01, 2011 - 09:33 PM UTC
Looking seriously cool!
Maybe I need to get one of them, too...
Guido
Posted: Tuesday, March 01, 2011 - 10:39 PM UTC
Looking good Jesper, nice Seehund !
I am on finals now:
Should be finished by tomorrow.
Julian
Posted: Wednesday, March 02, 2011 - 02:11 AM UTC
I'm calling the build finished, completing the campaign
The Beaver is tamed:
It's back to building the Revell Fletcher now for me.
Julian
CaptSonghouse
Posted: Wednesday, March 02, 2011 - 07:00 AM UTC
Brilliant work, Julian! The figure really puts the entire design in perspective.
--Karl
Posted: Wednesday, March 02, 2011 - 07:10 AM UTC
Thank you very much Karl.
Regards,
Julian
MrMox
Aarhus, Denmark
Posted: Wednesday, March 02, 2011 - 09:34 AM UTC
Nice beaver ... Like Karl I like the addition of a figure.
Cheers/Jan
Posted: Wednesday, March 02, 2011 - 06:59 PM UTC
Very kind of you Jan, thank you
Julian
Tailor
Posted: Wednesday, March 02, 2011 - 07:10 PM UTC
Well done, indeed!
Posted: Wednesday, March 02, 2011 - 07:59 PM UTC
Good morning Guido, thank you ! I loved your "tracked tadpole" diorama, that must have been a challenge in 1/72 scale.
regards,
Julian
SGTJKJ
#041
Kobenhavn, Denmark
Posted: Wednesday, March 02, 2011 - 10:12 PM UTC
Thanks for the comments, Julian and Guido. I had a major set back yesterday as I dropped one of the torpedoes onto a stone floor. Both the arming devise in the front and most of the propeller blades broke of. Very difficult to repair without it showing.
My plan about showing the seehund beached somewhere in Europe with just one torpedo just moved closer.
Nice build, Julian. The camouflage came out well. Damn, these things were small. Not for the claustophobic!
Tailor
Posted: Wednesday, March 02, 2011 - 11:40 PM UTC
I like the idea, Jesper!
Be aware that the boat would be washed into the sand. That way you could cover the wounds of your accidents.
Guido
