My build blog for Kaiten Type 1 – 1:72 Fine Molds Kit # FS1s
Fine Molds re-released their Kaiten Type 1 kit in conjunction with the release of the new film in Japan, in 2006. Do not confuse this special edition kit with kit # FNMFS1 which includes TWO kaiten subs in two sprues (is kit KS1 “half” of FNMFS1?).
Pic from Jan, but did not start the build till earlier this month due to the usual life-issues.
The kit has low part counts: 12 for the sub assembly and another dozen for the cart.
Some nice fine detailing in some parts, such as the hatch, molded welds and rivets, and cart. Props probably a tad thick; a small PE fret would have been welcome.
Cart fit was great. I think the hull fit was also good, except I mangled the mating. Nothing some putty smoothing and rivet/weld re-scribing could not fix:
Pictures of existing specimens show that the welding was really pronounced, and some of the casting was very rough:
I added some Mr Surfacer 500 to enhance the welds. I also dabbed some Mr S on selected parts of the hull to replicate the roughness of the cast metal:
I gently sanded down the Mr S. The hull was cleaned and washed, and primed
- At this point, I have primed and fixed couple details that got lost during manipulation. Obviously, I will not finish before the deadline today unless there is an extension
*hint hint* I will continue to post in any case
Any comments or feedback relating to accuracy, technique or aesthetics more than welcome!
