Hi all,
Well thankfully this weekend provided me with some bench time. I began the constructions of the AA platform by destroying the kit AA Platform.
Here are the two pieces of etch that compose the AA Platform base.
I used PVA to glue them together and then secured it to my cutting mat with tape for a good 18 hours. With the amount of handling I knew they would go through I wanted to make sure the glue was cured.
Here it is with the rails removed and the shields folded.
I will fold the rails and reattach them at a later date, probably just before it receives paint.
On a side note, all of those bright rectangle areas are for the 25mm ammunition boxes. Quite a few...
Well to build the AA Platform the FlyHawk kit calls for the destructions of kit platform, here is the beginning of the destruction
All of the supports, the large square boxes and the half round areas are required for the platform.
Once I was able to dry fit the platform it became quite obvious that I needed to get the funnels done before the AA Platform could be mounted, so I put the platform to the side and worked on the funnels.
The top funnel grates were a significant challenge but I was able to bend them enough the get them mounted. As you can see in the picture I still have some adjustments to make.
Since I do not want to run into the same problems I had painting the Musashi funnels the plan is to apply a layer of primer, mask, and then paint the funnels.
At the same time I will prime and paint the PE rails and ladders that go on the funnel still on the sprues then add them to the funnels. Should only need some touch up.
Anyway, I wanted to provide a teaser so here are a few shots with everything dry fitted.
Now she is starting to look like the sleek Heavy Cruiser she was before being sunk. More to come soon.
thanks for looking in and as always comments, suggestions, and criticism are always welcome.
