nearly
Nice progress Warren-you're nearly keeping up with Simon![]()
nearly![]()
Nice work Warren,
The Pontos single twenties appear a little fiddly, the only issue ,I had building them for the Duke was the fit of the shield mount to the pedestal, a few of them needed a little fettling to get the lug into the hole. The doo look really decent put together.
Your boot topping looks good - despite the in part complicated shape of the hull. The hull looks really good with all the camo on now!!
Hi Warren,
great progress!!![]()
Nice start on the 15"ers, that's quite an interesting ladder there on the back of the turret! Is that from the Pontos set? I haven't seen one shaped like that yet, looks good! And nice work on the 20 mm single. I would go for the brass - but that's just me![]()
Beautiful work on the fiddly parts there Warren! I would be hard-pressed for a decision on the guns too! Keep up the great work on this!
Nice Work on the 20mm Warren,
They will look the business mounted. The 4" look pretty good too.
Will you be fitting the brass barrels to them?
- I was talking about those as compared to the plastic 20mm's , not the 4" brass barrels in my post.
Thanks Warren,
They do look pretty good, and the breeches look nice too.
I will follow your lead when I get round to my Warspite.
Wow - mass production...![]()
It's great that you accepted the Pontos challenge of some 29 Oerlikons - they will stand out on your Warspite![]()
2-3mm short, that's pretty bad! Good to know, and no, I would not use them either.
Looking good Warren,
Did find with these mounts on the Duke the fit of the cradles onto the pedestals was poor, the holes were a little small, these look somewhat better.
Oh, and gluing them to that foam sheet using PVA wasn't such a ggod thing as when I removed them some of the foam stuck to each pedestal. Had to remove it and the glue with a knife and inevitably some of the carriages got knocked off the pedestals and had to be re-attached. Oh well....
