Well...hmmmm... actually no!
Can you post some pictures so that I can understand the problem better?
Skipepr
Hi Mike...
Skipepr
They're coming along really nice Mike. How many hours do you suppose you have in them thus far?![]()
I look forward to seeing the finished products!
Take care
Steve
Mike (Woodstock74),
Could you fix a piece of stiff wire or similar to the nozzle of each cannon, suspend the casement above the gundeck somehow then thread the wire through the gunports leaving the cannon near the centre of the deck. Spread some 5 minute epoxy on the deck where the guns will finally be positioned then glue the casement and hull together and drag the cannons into position using the wire.
Let it all dry and remove the wire. You'll just have to be careful with the epoxy or hope that it's not visible through the gunports when everythings finished.
hope to have helped.
Tom
I think what i would do is to set the guns in the gunports and glue a piece of sheet styrene under the cannon and to the wall of the casemate. After it dries and sets, then glue the casemate to the hull piece. I do love the way all those confederate Rams looked. The VA, TN, ARK, ATL and the ABER.
