Tuesday, August 04, 2015 - 12:43 AM UTC
Two new 'Master Tools' are due this winter. One is an electric sander/polisher and the other an electric cutter.
First up, the sander/polisher (No. 9939) is described as a being quick-charged tool using the included USB plug for the installed 3.7V/390 MAH built-in li-po battery. It includes 4 different polishing heads, water-soluble sandpaper and a polishing cloth.
The other, (No. 9952), is said to be suitable for use in cutting any metal or plastic pipes with diameters under 3.5mm. This cutter is quick-charged using the included USB plug for the installed 3.7V/390MAH li-po battery. It includes 4 different grits of 1” grinding wheels, which are screwed on and off the cutter as desired.
The sander/polisher has a suggested retail price of $54.95 (US) and the cutter, $59.95 (US). Both are due for a December release.
Only 1 reader has rated this.
THIS STORY HAS BEEN READ 9,891 TIMES.
| Trumpeter Reviews | MORE |
| USMC LCAC by HG Barnes | |
| DKM Type XXIII U-Boat by Harry | of 2 ratings, 100% found this helpful | |
| HMS Zulu by Todd Michalak | of 1 ratings, 100% found this helpful | |
| HMS Dreadnought 1907 by Jim Starkweather | of 2 ratings, 100% found this helpful | |
| USS Indianapolis by Chris Flodberg | |
| HMS Roberts by Todd Michalak | |
| HMCS Huron by Kevin Brant | |
| USS Missouri by Warren Inman | |
| HMS Belfast 1942 by Jim Starkweather | of 1 ratings, 100% found this helpful | |
| Bismarck by | of 6 ratings, 100% found this helpful | |
| German Z-25 1944 by David J. Salvin | of 1 ratings, 100% found this helpful | |
| DD-101 Murasame by Frank | of 1 ratings, 100% found this helpful | |
| USS Sacramento AOE-1 by Jim Adams | of 3 ratings, 100% found this helpful | |
| 1/200 Scale USS Arizona by | of 6 ratings, 100% found this helpful | |
| USS Hornet 1/350 by Dariush | |
