1⁄35Making a Water Base, Step-by-Step
8
step 1, and a 2. . .
Start off by squeezing out a fair amount of latex tub and tile caulk. Then, using your foam brush spread the caulk out evenly over the base.
Once you have covered the whole base, use a stabbing motion to create the waves. (Photo 3) If you don’t like your results, simply smooth the caulk out and try again. Once you get the water looking like you want it, set the base aside to dry (putting it in front of a fan greatly speeds up the drying time.
Umm... not seeing anything here Mark... easy on the rum there matey[/quote]
Darn html tag...
Thanks for the heads up, brother Tarok!
JUN 17, 2007 - 08:26 AM
Disclaimer:
No bodily injuries were inflicted during the making of the wood base.
Just for you Jake.
JUN 17, 2007 - 01:24 PM
Hey Kenny,
excellent technique and article, I book marked as I'm hoping to do this over the summer. One question, in the last stage, making the wakes. What and how are the blended into the water. Did you smooth them in and how does the brightness of the white blend in. Thanks..
JUN 17, 2007 - 03:51 PM
Hey Joe,
I got back with my paints an blend them in to the surrounding colors. When making the wakes, I wet the brush with water to blend it into the base.
Hope this helps.
JUN 18, 2007 - 12:16 AM
Thanks for the info Ken. I especially like the "splash" effects.
As we say in Florida, Go Gator!
JUL 09, 2007 - 01:11 PM
Copyright ©2021 by Kenny Loup. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-06-17 00:00:00. Unique Reads: 16193
