1⁄35Making a Water Base, Step-by-Step
8
Attaching the water splashes and ship. . .
Using a drill bit the same size as the armature, drill a hole through the caulk and the wood base. Insert the splash through the whole, cut the armature flush with the base bottom and super glue into place. (Photo 19) After your splashes are glued in, attach the ship to the base using super glue. (Photo 18) If the caulk gets displaced, don’t worry. Carefully work it back in to place with a q-tip.
Working with the water splashes. . .
Take your silicone caulk and squeeze out a small amount around the splash. (Photo 20) Using your scrap piece of wood, work the silicone away from the splash in a circle, mimicking a wave. (Photo 21 and 22)
Umm... not seeing anything here Mark... easy on the rum there matey[/quote]
Darn html tag...
Thanks for the heads up, brother Tarok!
JUN 17, 2007 - 08:26 AM
Disclaimer:
No bodily injuries were inflicted during the making of the wood base.
Just for you Jake.
JUN 17, 2007 - 01:24 PM
Hey Kenny,
excellent technique and article, I book marked as I'm hoping to do this over the summer. One question, in the last stage, making the wakes. What and how are the blended into the water. Did you smooth them in and how does the brightness of the white blend in. Thanks..
JUN 17, 2007 - 03:51 PM
Hey Joe,
I got back with my paints an blend them in to the surrounding colors. When making the wakes, I wet the brush with water to blend it into the base.
Hope this helps.
JUN 18, 2007 - 12:16 AM
Thanks for the info Ken. I especially like the "splash" effects.
As we say in Florida, Go Gator!
JUL 09, 2007 - 01:11 PM
Copyright ©2021 by Kenny Loup. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-06-17 00:00:00. Unique Reads: 16193
