1⁄35Making a Water Base, Step-by-Step
8
When it’s dry, take a piece of cardboard and trace the outline of the hull and cut out the shape. (Photo 13) Use the cardboard as a template to cut the caulk where you want to place your ship. I use an X-acto knife for this. After you cut the caulk, remove it from the base (photo 14). This can get messy, so be prepared. Also, don’t worry if the caulk hasn’t cured underneath the top layer. This will help you close up any gaps when you install the ship. (Photo 15)
Now, let’s paint. I find going online and doing a Google image search as the best way to find out just what color to paint the water. I use acrylic craft paint to paint my water. (Photo 16) It will take two coats of the base color to make the water opaque. While the second coat is still damp, I will mix in a darker shade to give the water color some variation and depth. (Photo 17) Once you have your colors on, set the base aside to dry.
Umm... not seeing anything here Mark... easy on the rum there matey[/quote]
Darn html tag...
Thanks for the heads up, brother Tarok!
JUN 17, 2007 - 08:26 AM
Disclaimer:
No bodily injuries were inflicted during the making of the wood base.
Just for you Jake.
JUN 17, 2007 - 01:24 PM
Hey Kenny,
excellent technique and article, I book marked as I'm hoping to do this over the summer. One question, in the last stage, making the wakes. What and how are the blended into the water. Did you smooth them in and how does the brightness of the white blend in. Thanks..
JUN 17, 2007 - 03:51 PM
Hey Joe,
I got back with my paints an blend them in to the surrounding colors. When making the wakes, I wet the brush with water to blend it into the base.
Hope this helps.
JUN 18, 2007 - 12:16 AM
Thanks for the info Ken. I especially like the "splash" effects.
As we say in Florida, Go Gator!
JUL 09, 2007 - 01:11 PM
Copyright ©2021 by Kenny Loup. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2007-06-17 00:00:00. Unique Reads: 16193
