Make Your Own Rope Rigging
5
Single Handcrank
I strongly recommend that you use a hard wood such as oak, and to clamp down both ends of the board to a table. By turning this handcrank the top will slowly move away from the crank. This rope walk will not work, if you use weak strands of thread.Comments
FEB 22, 2008 - 05:53 AM
FEB 22, 2008 - 08:41 AM
FEB 23, 2008 - 03:19 PM
MAR 25, 2008 - 06:19 AM
