Make Your Own Rope Rigging
5
Crewmate Den Holmes shows us his method of making your own rigging using a "Rope-Walk" in this Step-By-Step feature!
The term ropewalk drives a horrible fear into many ship model builders, and it becomes almost a matter of
avoiding the subject at all cost. However, for a very small "cost" and a little effort you can make your own
ropewalk. With only a few minutes of further time you can learn to use it productively. This ropewalk is 3' long,
and made out of pine.
FEB 22, 2008 - 05:53 AM
FEB 22, 2008 - 08:41 AM
FEB 23, 2008 - 03:19 PM
MAR 25, 2008 - 06:19 AM
Copyright ©2021 by Den Holmes. _OPINIONS Model Shipwrights, KitMaker Network, or Silver Star Enterrpises. Images also by copyright holder unless otherwise noted. Opinions expressed are those of the author(s) and not necessarily those of Model Shipwrights. All rights reserved. Originally published on: 2008-02-22 00:00:00. Unique Reads: 26452
