Make Your Own Rope Rigging
5
Top Close-up
The Top has 3 grooves, on it so that the strings will glide in the grooves. It also has a 1/8" hole drilled through the center of the Top, for a 4 stranded rope.Comments
FEB 22, 2008 - 05:53 AM
FEB 22, 2008 - 08:41 AM
FEB 23, 2008 - 03:19 PM
MAR 25, 2008 - 06:19 AM
