Make Your Own Rope Rigging
5
Moving on...
As you turn the left end will try to move toward the right end since the rope is shortening due to the twisting of the yarns. Let the movement occur, but do not let the rope go slack There should be some tension in the threads, and the tension should be about equal between the strands. Shows the Top gliding along the black strings, as either the right or left crank is being turned.Comments
FEB 22, 2008 - 05:53 AM
FEB 22, 2008 - 08:41 AM
FEB 23, 2008 - 03:19 PM
MAR 25, 2008 - 06:19 AM
