Make Your Own Rope Rigging
5
ROPEWALK left end
To practice with the ropewalk, clamp the wood base to a table, so it dont move while working. Place, one, three or four pieces of common thread ("yarn") on one of the hooks, on the right end. This thread goes to the single rod on the left end. There should be some tension in the threads, and the tension should be about equal between the strands.Comments
FEB 22, 2008 - 05:53 AM
FEB 22, 2008 - 08:41 AM
FEB 23, 2008 - 03:19 PM
MAR 25, 2008 - 06:19 AM
