Make Your Own Rope Rigging
5
ROPEWALK, single crank
This is a photo of the left end where all the strings are tied to a single rod. There should be some tension in the threads, and the tension should be about equal between the strands.Comments
FEB 22, 2008 - 05:53 AM
FEB 22, 2008 - 08:41 AM
FEB 23, 2008 - 03:19 PM
MAR 25, 2008 - 06:19 AM
