14
riding the wave...
After shaping the wave, I added a frame from 3mm plastic sheet. It’s some kind of recycling material so it was quite cheap. Again, trying something new saved me a lot of money, as using Evergreen would have cost a lot more than the 1.95€ I had paid for a 50x30cm sheet.
In the next step the whole scene was painted with thick layers of acrylic gel. When you take your time, the gel starts to set while you work. That gives you chance to sculpt structures and wave patterns.
I start by using a 1" putty knife to apply the gel to the base. Trying to smooth out all irregularities of the styro-foam surface, I try to spread it as even as possible. It's like making the perfect peanut butter sandwich (not crunchy!). I take care to smooth over and over in the directions the wave would be moving.
The artist acrylic gel I use starts to set on the surface already after about 8-10 minutes. So basically, the setting starts as soon as I have applied an evenly thick and smooth layer over all. You can feel the setting in as soon as the gel starts sticking to the putty knife better than to the sea-scape: This is your time to go and clean the spade thoroughly, allowing for a tad bit of additional drying time.
Out comes the 1.5" wide brush. Its one of those cheap, hardware store, 5-in-a-bag brushes, that you would usually use for painting your fence and throw it out afterward (the brush - not the fence!). Slightly moisten the brush before starting to move the tip of it carefully over the surface of your sea-scape. Use no pressure whatsoever...you'll see the brush will pick up the dried surface and drag the layer below with it. This is all it takes!
When creating the surface of your seascape take care to start at the crest and continue towards the trough in short and smooth flicking motions. The bigger the scale the longer the flick. (does that make sense?!) If you picture in your mind the intended weather conditions (light wind or storm, rain, shine, etc.), you’ll automatically know when you overdo the “turbulence at the surface”.
As said, with my type of gel I do not need to wait that long, but I certainly would recommend against using a blow dryer to quicken the process of drying. Natural drying time is best. The effect of the blow drying may be – worst case scenario – that the surface is dry while the underlying layer, has no time to “exhale” its liquefying solvent, staying in a sticky, half-dry condition. The other effect would/could be that you get too high a tension on the surface. The gel will contract a little while drying, giving tension to the Styrofoam and lifting up the corners and edges of your display. It even happened to the 3” sandwich that I created for his wave. I assume that quick-drying could essentially worsen the effect.
On top of it: Go slow! The art of model building is not a sprint race, it is long distance running: Sometimes it’s the track, sometimes it is cross country, but it’s hardly ever quick.
I used the gel to make the gap between the frame and the Styrofoam vanish, too.
After some days I got back to the base and found that the crest had sagged while setting. So I added another layer for the crest.
After another day of drying I, smoothed over the edges of the frame and primed the whole assembly. I used a primer usually used for figure painting...I found that stuff excellent for application of acrylic artists paint and it’s quite a bit cheaper than Mr. Hobbies product.
MAR 10, 2010 - 07:48 AM
Hi Guido!
--Karl
MAR 10, 2010 - 10:57 AM
Guido
MAR 11, 2010 - 03:23 AM
Cheers/Jan
MAR 11, 2010 - 04:08 AM
Hallo Guido
Tschuss,
MAR 16, 2010 - 07:19 AM
MAR 16, 2010 - 08:30 PM
Guido
MAR 16, 2010 - 08:42 PM
MAR 20, 2010 - 06:16 AM
