14
Affixing the Andrea Gail...
With the sea-scape basically ready, I decided to place the boat before fixing the seascape to the wooden socket. So I put the AG into her final position and traced the hull outline with a white pencil. Then I cut the outline with an x-acto #11 blade, and lifted the hardened surface off of the styro-foam.
With a few cuts I adjusted a cavity to fit the hull. Satisfied with the position and setting of the AG, I painted the water churned up by her hull and propeller.
With a blend of gel and white paint, I filled the gaps along the hull, and build up the bow and stern wake...
After an hours time I blended the wakes by dry brushing, this time using clean white, as the highest color...
...… next stop: Fixing the seascape to the wood base.
MAR 10, 2010 - 07:48 AM
Hi Guido!
--Karl
MAR 10, 2010 - 10:57 AM
Guido
MAR 11, 2010 - 03:23 AM
Cheers/Jan
MAR 11, 2010 - 04:08 AM
Hallo Guido
Tschuss,
MAR 16, 2010 - 07:19 AM
MAR 16, 2010 - 08:30 PM
Guido
MAR 16, 2010 - 08:42 PM
MAR 20, 2010 - 06:16 AM
