14
Since the AG will be placed in a seabed, I don’t have to worry about the lower hull features.
To get an even surface I glued a piece of sheet to the bulkhead and applied a Gold Medal Models WT Door to get a sense of scale. In a next step I scribed an uneven pattern of steel deck panels onto the weather deck (made visible with pencil dust for you) and cut the fishing net chute into the stern. Then the chute is covered up at the deck again, as it is not in used on those swordfish boats.
Next would be the bumper guards around the hull. The sandwich structure of the hull provides me with a good guiding line for the lower bumper guard. I attach a .5 mm round strip from Lion Roar on the stern and let the glue cure thoroughly.
While the glue cures, I start the upper deck construction. I had trace the forecastle shape onto a piece of paper, which I scanned and scaled down until the shape was just a bit smaller (about .05mm along the leading edges) than the actual forecastle of the hull. This deck shape was extended by the overhanging part into back. Again I printed the shape onto a paper sticker, applied it to styrene sheet, cut it out, and smoothed the edges over.
MAR 10, 2010 - 07:48 AM
Hi Guido!
--Karl
MAR 10, 2010 - 10:57 AM
Guido
MAR 11, 2010 - 03:23 AM
Cheers/Jan
MAR 11, 2010 - 04:08 AM
Hallo Guido
Tschuss,
MAR 16, 2010 - 07:19 AM
MAR 16, 2010 - 08:30 PM
Guido
MAR 16, 2010 - 08:42 PM
MAR 20, 2010 - 06:16 AM
