14
When the styrene joints are sufficiently dry, I remove the part from the model for painting. To remove the part do not pull it away, but use tipped pliers to pick at the Maskol globs one by one. It seemed easier from me to attach the top railing only now.
Another prominent sub-assembly is a big basket holding net/line floaters it is positioned on the port side of the weather deck, right aft of the flying deck. This little sucker is only about 10mm tall, but took me almost 2 hours to make.
On to build the outriggers...They turn out to be the nastiest part of the build so far: 5 beams and 5 bracing can’t be that hard to build! Well, if it wasn’t for their curved shape...Ok, here is the start;
This task was enough to make me completely mad, and I didn’t like the result one bit, so I turned to weathering and dry brushing the boat!
MAR 10, 2010 - 07:48 AM
Hi Guido!
--Karl
MAR 10, 2010 - 10:57 AM
Guido
MAR 11, 2010 - 03:23 AM
Cheers/Jan
MAR 11, 2010 - 04:08 AM
Hallo Guido
Tschuss,
MAR 16, 2010 - 07:19 AM
MAR 16, 2010 - 08:30 PM
Guido
MAR 16, 2010 - 08:42 PM
MAR 20, 2010 - 06:16 AM
