Official Campaign: MTB
beefy66
KitMaker: 971 posts
Model Shipwrights: 645 posts
Posted: Wednesday, September 25, 2013 - 07:38 AM UTC
Another update I have added some beading around the area where the water will be to give it some hight and have fixed the insulation foam in place using decorators calking sealer. After this had set I have started to add some waves to the foam using a cutting disc and small sanding drum in my mini drill and some work on the vosper I have added the kit PE to the controls on the flying bridge.First time I have used Gator glue for the PE fixing and found it very good to work with.
beefy66
KitMaker: 971 posts
Posted: Wednesday, September 25, 2013 - 07:47 AM UTC
Warren hope you enjoy the PT when you come to build it that is a really nice kit to this is the one I did for the Stand by Torpedos campaign
AlanL
KitMaker: 14,499 posts
Posted: Thursday, September 26, 2013 - 09:29 AM UTC
Looking good folks.
beefy66
KitMaker: 971 posts
Posted: Tuesday, October 01, 2013 - 11:18 PM UTC
Small update on the dockside build after the PVA coating on the insulation foam I sprayed a light coat of primer to show up some of the gaps which I filled with tube filler can you tell me if you think the boat is sitting to high or low in the water I have also replaced the grab rails with solder wire to make them look damaged and added more texture to the walls and will be adding seaweed with some garden moss and scater grass
MichaelSatin
AEROSCALE
KitMaker: 3,909 posts
Model Shipwrights: 255 posts
Posted: Wednesday, October 02, 2013 - 12:13 AM UTC
I think it looks fantastic Keith. Perhaps riding a bit high, though I could certainly be wrong. Maybe it's low on fuel.
AlanL
Posted: Thursday, October 03, 2013 - 01:14 AM UTC
Excellent progress Keith.
beefy66
KitMaker: 971 posts
Posted: Tuesday, October 08, 2013 - 06:20 AM UTC
Small update not so good with things when working nights I have started adding the seaweed to the dock walls I think I may have over done it but will be abla to thin it out later when the PVA glue has fully dryed. You can see better in this photo the texture I have made with the mini drill to the wall as the kit parts come fairly flat faced.
Keith
Grauwolf
#084
Quebec, Canada
KitMaker: 2,485 posts
Posted: Friday, October 11, 2013 - 03:47 PM UTC
Looking good.
Posted: Sunday, October 13, 2013 - 06:55 AM UTC
Great builds going on here, loving this campaign.
After a bit of a hiatus I have got going again, started on the base., the structure of the wake is laid out.
The plastic rod is stuck down, trimmed and covered in kitchen foil.
and then sprayed with a mix of green, blue & grey and the boats placed back on after the paint had dried.
next will be a the "base of the wake airbrushed on in white.
MichaelSatin
AEROSCALE
Posted: Sunday, October 13, 2013 - 11:18 AM UTC
Nice work Si!
AlanL
Posted: Sunday, October 13, 2013 - 08:38 PM UTC
Hi Simon and Keith,
Excellent progress. Keith what did you use for the seaweed?
Thanks
beefy66
KitMaker: 971 posts
Posted: Sunday, October 13, 2013 - 11:28 PM UTC
Hi Alan I used dryed out moss from my garden along with some model railway grass scater for the seaweed giving it some time to dry and then will trim it back a bit.
Simmon looking good with your seabase
Cheers Keith
beefy66
KitMaker: 971 posts
Posted: Thursday, October 17, 2013 - 10:10 PM UTC
Sorry folks no updates as having computer problems will get sorted soon and show more of the build soon
Cheers Keith
warreni
South Australia, Australia
KitMaker: 5,926 posts
Posted: Sunday, October 20, 2013 - 08:34 PM UTC
I are finished the Vosper. There is a photo feature online if anyone wishes to have a look.
I uploaded some to the gallery as well.
Warren
Grauwolf
#084
Quebec, Canada
Posted: Sunday, October 20, 2013 - 11:48 PM UTC
Now that is an interesting approach to creating the wakes.
Really like it.
MichaelSatin
AEROSCALE
Posted: Monday, October 21, 2013 - 04:53 AM UTC
Warren
Warren, Nice work! By the way, the gallery's here if anyone wants a look at Warren's great Vosper.
The PT 109 still lives:
Those tubes on the port side aren't attached, just sitting there to show some progress. Hopefully I'll be able to concentrate on getting further now that I've finished up a couple of other projects.
Posted: Thursday, October 24, 2013 - 07:34 AM UTC
Looking good Michael,
Got the airbrush out and did some work on the base level of the wake. as you can see I still have a lot to learn about airbrushing.
the boats sat on the base.
and the base of the propwash added.
a few coats of sea and wake and it should have a bit of depth.
More soon
Posted: Friday, October 25, 2013 - 06:40 AM UTC
Very quick update, some more work on the boats, mostly the armament.
624 has had the 6 pdr added fwd amd the twin 20mm MkV aft along with the L'Arsenal resin barrels, just needs the etched sight.
794, the aft 6pdr, the base plate & L'Arsenal resin pedestal for the twin manual 20mm, work has alos started on the twin 0.5" Vickers.
MichaelSatin
AEROSCALE
Posted: Tuesday, October 29, 2013 - 05:13 AM UTC
They're really moving now Si!
Meanwhile, the 109 is finally a torpedo boat!
Getting somewhere now. Finally.
IronOwl
Georgia, United States
KitMaker: 572 posts
Model Shipwrights: 80 posts
Posted: Monday, November 04, 2013 - 03:41 PM UTC
wow those Boats are looking good. am hoping to dig into mine soon trying to clear up some room on my work bench.
Sascha(Ironowl)
MichaelSatin
AEROSCALE
Posted: Sunday, November 10, 2013 - 01:35 PM UTC
Sascha: I know just what you mean. Right now, this is what I'm trying to finish so I can get on to the next thing (which I think will be a WNW 1/32 Snipe!)
So, here's where I am on the 109:
I'm working on the bow 37mm right now. Wow, it's probably more intricate than anything else in the kit. It will be painted OD (I figure they didn't have time to repaint given how temporarily it was secured to the deck) so it should be an interesting contrast.
May get this done yet!
MichaelSatin
AEROSCALE
Posted: Monday, November 11, 2013 - 10:21 AM UTC
And finished!
Just in time for Veterans day here in the states. More pics in the gallery , of course. I kind of mixed features based on how I wanted it to look. They seemed to have over-painted the windscreen and left off the mast, so I did those things. Chances are, however, they painted over the compass housing and wood gratings and benches that I went ahead and painted as black and wood for a little contrast. I also painted the mufflers my burnt metal mix for the same reason. As I have mentioned, the patchiness to the green is because Tamiya's paint as airbrushed out of the bottle doesn't exactly match the rattle can. Still, I think it's effective weathering. At least that's my story.
I think it came out pretty well. My biggest advice is to watch out when handling it if you build. The rudders and prop shafts break easily but are tricky to install when everything else is done too. Think it out before hand and have plenty of room!
Looking forward to everyone else's builds!
beefy66
KitMaker: 971 posts
Posted: Monday, November 11, 2013 - 11:57 PM UTC
Hi Michael looking great just got my computer back from the repair shop will hope to get some updates posted soon on the dockside build would you be able to post some close up photos of your 109 to give us some detail shots if possible
Cheers Keith
MichaelSatin
AEROSCALE
Posted: Tuesday, November 12, 2013 - 12:44 AM UTC
Cheers Keith
Keith,
I have some in the gallery but could try to add some more later today. Glad you like it! Looking forward to your scene.
sweaver
Kentucky, United States
KitMaker: 759 posts
Model Shipwrights: 19 posts
Posted: Wednesday, November 20, 2013 - 06:29 AM UTC
I assume a submarine does not fit within the rules of this campaign?
