Ships by Class/Type
1/350 Tamiya KAGERO with Inifini upgrade.
Posted: Monday, November 27, 2017 - 04:48 PM UTC
that's a crazy looking mast!
Posted: Monday, November 27, 2017 - 10:19 PM UTC
It is Russ,
The V shaped upper yard and the rake meaning all the halyard run forwards help. It was "fun".
Posted: Monday, December 04, 2017 - 02:06 AM UTC
A little progress on the turrets and tubes.
These seems to be a very large number of tiny etched parts, but I will get there!
Posted: Tuesday, December 05, 2017 - 01:18 AM UTC
Si, you're right, there are a lot of those tiny etched parts, but they are going to look great under paint!
Posted: Tuesday, December 05, 2017 - 01:40 PM UTC
a LARGE number of TINY PE, i see what you did there Si
Posted: Wednesday, December 06, 2017 - 01:13 AM UTC
Thanks Tim,
They will be worth the effort... if I don't go cross-eyed in the process.
Posted: Wednesday, December 06, 2017 - 01:17 AM UTC
a LARGE number of TINY PE, i see what you did there Si![]()
Sometimes I really do need read back what I have typed more carefully!
Posted: Thursday, December 07, 2017 - 07:00 PM UTC
Nice work on those turrets. I always have problems putting on those PE rails on the sides of the turrets to stay in place. How do you get those darn things to stay in place?
Posted: Saturday, December 09, 2017 - 01:00 AM UTC
Nice job and progress here as well, SI!
Perfect etch work for the guns and torpedo tubes, and the mast is interesting, indeed.
The whole bridge looks so 'WW I-ish' to me, but they were quite modern WW II vessels, weren't they?
Posted: Sunday, December 10, 2017 - 08:01 PM UTC
Hi Mark,
Thanks for your comment. I use Gator glue to fix the rails, I apply I line of it along the top edge of the moulded rail, and let it start to go a bit see through, so it is tacky, the work the rail into place a bit at a time. I find superglue always tends to grab a bit of it in the wrong place and not let go. this way I have time to work inot place one section at a time.
Posted: Sunday, December 10, 2017 - 08:05 PM UTC
Thanks Mate,
These Japanese warships do have unusual design features.
The bridge does belay the fact that they were a mid 30's design, but the Japanese used a similar style of bridge form most of the destroyers from that period onwards, I can only presume it worked as a design.
