The lower bridge sections.
Prior to removing the detail as per the Pontos instructions.
After.
I decided to have one of the W/T doors into the superstructure open, slight issue, the frame for that side ping into an alternative universe. Quick bit of scratchbuilding problem solved.
Brass cladding on the upper front section.
Sone cladding is provided for the rear section, but somehow it fouled the gangways. The hatches were fitted directly on to the plastic.
The view through the open door.
I might do the same for the after superstructure.
