Hi Tim,
On the whole this kit is pretty good, but to be honest I wasn't that impressed with the kit winches either.
I think the skylights, once painted are going to be a bit tasty too, especially the with a couple of them open.
Thank you for looking in.
Posted: Monday, January 28, 2019 - 05:24 AM UTC
Posted: Friday, February 01, 2019 - 07:12 AM UTC
More skylights / vents.
some vent boxes are etched in two parts due to their shape.
two boxes assembled, one closed, one open.
I managed to feed the floor monster with hatches, so a bit of pkasticard, some wire for the gasket, and with a bit of luck under a coat paint, it will look ok.
Test fitted in place.
all the centre castle vents / skylights done. A few rigging points to be attached to the boiler casings, then painting.
Posted: Friday, February 01, 2019 - 11:47 AM UTC
Good Lord, Si! All of that PE detail is smashing!
Gaz
Gaz
Posted: Friday, February 01, 2019 - 12:20 PM UTC
Excellent PE work.
Excellent PE work.
surfsup
Posted: Friday, February 01, 2019 - 03:37 PM UTC
Lovely work with the P/E Si.....Cheers Mark
Posted: Friday, February 01, 2019 - 09:44 PM UTC
Thanks chaps,
The Pontos etch has a lot to do with that, good sharp fold lines are a great help, especially on the long folds.
Posted: Tuesday, February 05, 2019 - 08:32 AM UTC
The weekend's progress.
rigging attachment points fitted to the after casings and vents.
all sprayed off white.
and fitted in place.
As the weather turned against me for spraying, I just managed to get the cable ways sprayed dark grey and washed black, same technique as the coaling hatches.
Hopefully will get some more spraying done shortly.
Posted: Tuesday, February 05, 2019 - 12:22 PM UTC
So much detail on this one Si, but expert hands are in control
Posted: Tuesday, February 05, 2019 - 01:09 PM UTC
Looking good, Si. The detail is building up, layer by layer!
Posted: Tuesday, February 05, 2019 - 01:59 PM UTC
So much detail on this one Si, but expert hands are in control![]()
Ditto!
Posted: Wednesday, February 06, 2019 - 06:33 PM UTC
Awesome work, Si!
Posted: Thursday, February 07, 2019 - 04:56 AM UTC
Kind of you to say so Russ,
Not sure about expert, sometimes certainly a little nervous.
Posted: Thursday, February 07, 2019 - 04:59 AM UTC
Thanks Tim,
I hope when I have got the paint on the depth in the detail will come out.
Posted: Thursday, February 07, 2019 - 05:01 AM UTC
Quoted TextSo much detail on this one Si, but expert hands are in control![]()
Ditto!
Thanks Mark,
The quality of what I am working with helps it look that way.
Posted: Thursday, February 07, 2019 - 05:03 AM UTC
Awesome work, Si!
Thanks Gaz,
Appreciate your kind comment.
Posted: Friday, February 08, 2019 - 07:31 AM UTC
A little progress this week.
A break in weather yesterday meant I a chance to get the brass sprayed.
black wash put in the skylights, the winches and rope drums have had some colour applied.
The winches washed, the drum of wire, gloss dark brown, and the drum matt rusty dirty mid brown.
The portholes glazed with KK.
The beginning of the fitting.
More soon.
More soon.
Posted: Friday, February 08, 2019 - 10:55 AM UTC
Nice.
Posted: Friday, February 08, 2019 - 01:53 PM UTC
Those tiny details will fill up the decks nicely, Si!
Gaz
Gaz
surfsup
Posted: Friday, February 08, 2019 - 02:51 PM UTC
Very nice detail work Si. Certainly adds to the overall effect.....Cheers mark
Posted: Friday, February 08, 2019 - 11:54 PM UTC
Nice.
Mark![]()
Thanks Mark,
the quality of the brass helps.
Posted: Friday, February 08, 2019 - 11:56 PM UTC
Gaz
Thanks Gaz,
one thing with 1/200th, these details are more manageable.
Posted: Friday, February 08, 2019 - 11:58 PM UTC
Thanks Mark,
I like the larger scales, but the extra depth in the detail is needed to stop it looking toylike.
Posted: Monday, February 11, 2019 - 09:12 AM UTC
This weekend's progress.
all the inner skylights fitted.
outer skylights and cable reels fitted.
the group of open skylights.
The little problem with the top of the hawse pipes and the deck not quite being the same sorted with some black paint.
Cable ways and fairleads fitted.
close up showing the section of wood on the inboard side of the fairleads.
strengthening around the hawse pipes, three pieces of etch layered up, to give depth and detail.
in place.
The main capstans painted and some washes applied.
More etched detail down on the deck along with the capstans and covers to the spurling pipes.
More soon,
in place.
More soon,
surfsup
Posted: Monday, February 11, 2019 - 12:35 PM UTC
Some very nice detail starting to show through now Si. Excellent work Mate.....Cheers mark
Posted: Monday, February 11, 2019 - 08:44 PM UTC
Thanks Mark,
I am enjoying the larger scale, but it does need that extra bit of work to get the depth.
