23
Stage 29: boats and rafts
Kit parts: 14
Resin parts 10
Scratch parts: 37
PE parts: 68
Time: 8.5 hours
The kit supplies two 26ft motor whaleboats, a 40ft motor launch and a 36ft motor boat. Construction was straightforward using the kit parts and the GMM PE set. I used a mini power tool with a ball-tipped grinding bit to remove the davit sockets inside the whaleboats, and added a cover to the engine compartment in the 40ft launch.
Work on the kit-supplied rafts for the outboard side of the stack involved drilling and cutting out the moulded-in bases and replacing with the GMM PE parts representing the netting. In addition, four paddles from the GMM set were added to each float. Two water barricoes (UK spelling, pronounced ‘breaker’ and spelt that way in the US), cut from styrene rod, were placed in each raft running fore and aft (not athwart as in the moulded kit parts).
The only published photographs of the port side of the ship following her final refit were taken during the Battle of the Coral Sea. It is possible to make out that rafts were mounted on the inboard side of the stack.
Above: Life rafts discernible on inboard side of stack.
For the model, these came from the Voyager resin/PE set which was introduced while I was working on the model. These are rather smaller than the kit-supplied items, and the ends are semi-elliptical rather than semi-circular. But there was nothing else more suitable available at the time – the L’Arsenal products are not right because they are the rectangular pattern. The paddles supplied for the Voyager items were grossly over-sized, so I used up spares left over from the GMM PE set.
Stage 30: boat handling davits
Kit parts: 4
Scratch parts: 30
PE parts: 6
Time: 2.75 hours
The davits in the port side boat pockets were vertically pivoted and swung outboard through the horizontal plane. These were massive, cantilevered assemblies that had to be able to handle a 25-ton boat. Vertical spindles (styrene rod) were push-fitted into vertical holes drilled down through the edge of the flight deck and through the top of the boat pocket mouldings. Adjusted for height, they were then trimmed off at flight deck level. I tried unsuccessfully to stretch sprue for the davits with the right diameter and the correct taper. The solution was to use barrels from the discarded 5-inch guns in the kit. Dimensionally and for taper these were practically perfect. Pulley sheaves on the outer ends were made from thin slices of styrene rod.
Above: Vertical spindles for boat davits
Above: Completed boat davits.
Davits for the two whalers outboard of the bridge structure were made from brass wire. Each pair was shaped around a suitable diameter drill bit to give the correct radius then snipped in two. The hull-mounting brackets were made from a single wrapping of modelling masking tape. The gripe bars were also made from brass wire, with a single wrapping of masking tape for the gunwale pads. Boat lowering blocks were made from thin slices of styrene rod.
It should be noted that the spacing between the whaler davits provided for in the kit plastic deck is much to close. The same applies to the davit fall sockets in the whalers, which were removed.
Above: Scratch-built whaler davits.
Hi Joseph,
JUL 08, 2008 - 05:36 AM
Hi Rui
Regards, Chris
JUL 08, 2008 - 05:48 AM
Jim
Regards, Chris
JUL 08, 2008 - 05:53 AM
Thanks for the link, and since my memory is better for graphics, than for names, I can say that I had already seen your Sara / Lex duo in MW.
JUL 08, 2008 - 05:57 AM
JUL 11, 2008 - 08:46 AM
Hi Chris,
JUL 15, 2008 - 07:06 AM
Hello Chris:
I just finished reading your build log. Outstanding work and very well written. I have this kit, not sure I want to tackle all the inaccuracies vice just building an OOB kit, but, your work is inspirational and you presented a lot of neat ideas to enhance the kit. I will be referencing your build log when I tackle mine. Thanks for posting and sharing.
FEB 10, 2015 - 08:49 AM
FEB 10, 2015 - 09:13 AM
wow, awesome model building.
FEB 11, 2015 - 09:17 AM
