Gentlemen,
To make good use of drying time in another project I have been diving through my stash to find a project that may be finished in due time for this campaign.
I have decided to build the SMS Saida of the K+K navy. There is a good base of information to be found on the net about the ship and her sisters (SMS Helgoland, SMS Novara). You can’t really trust the picture captions on the net, they are mostly wrong but the differences between the ships are quite small.
The kit used is of the German defunct DOC Models or WSW. It contains only a hull and a handful of parts on wafers and no PE at all. Most of the parts will be replaced by details PittRoad, Combrig, Battlefleet Models and scratch building. PE will be taken from a variety of Lion Roar and WEM sets. The kit features resin masts which will be replaced by products from NNT and BMK.
The hull is straight and all cast structures seem in good alignment with the centreline. The measurement is correct. The cast on detail isn’t very pronounced, but mostly usable. There are a few cast inclined ladders, which will be replaced with PE. The hull lacks a number of portholes and the armour belt isn’t cast so well.
The hull is cast down to the waterline. Sine I will have the ship displayed at sea I need a little more hull underneath the boot topping line. So I glue a 1mm styrene sheet to the bottom, which then is shaped by Dremel and sanding stick to confirm to the lines of the hull. At the same time I remove the armour belt.
TBC
Guido
